1988 Blazer K5 Silverado Transmission problem, help.
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by blazer88, Dec 9, 2000.
  1. blazer88
    blazer88 Registered Member
    Dec 9, 2000
    67
    Fresno, CA
    We bought and 88 Blazer in good shape not to long ago, we replaced the piston and spring in the transmission(automatic) because it kicked, largely, and made a clunking noise, after it was replaced and programed, the problem did not go away, can anybody help me out, would we need to rebuild the transmission, or install a shift kit, if we need to go with a shift kit what does it do, or is it another part not having to do with the transmission?
  2. Corey-88K5
    Corey-88K5 1/2 ton status
    720
    Home: Michigan, Stationed: Hill AFB (Home of Moab.
  3. coopertwpk
    coopertwpk 1/2 ton status
    Mar 18, 2000
    478
    Spring Valley Lake Ca.
    Also it ma y be the slip joint on the drive shaft sliding in this is because your spring bushings are worn out so your spring pack tilts shoving your driveshaft forward .
  4. JimmyDie6.2
    JimmyDie6.2 1/2 ton status
    Jun 20, 2000
    453
    Long Island
    check your universal joints also....js
