1988 K5 silverado... 2 knock sensors or two Coolant temp sensors?
Discussion in 'The Garage' started by dirtwarrior17, Apr 1, 2005.
  1. dirtwarrior17
    dirtwarrior17 Banned
    May 14, 2004
    1,820
    Redding, CA
    I got an extra sensor left over from my 88 block to '79 block swap and i don't know what the hell it is. The motor runs fine without it and it either senses vibration or temperature. I don't have pics........
    Any ideas?
    I know some models had 2 cts or two knock sensors just not which models.
    Where does it go?
  2. 90blzr
    90blzr 1/2 ton status
    Mar 25, 2001
    3,027
    SO CAL
    You got the one in the front of the intake? (coolant temp), its kinda hidden.
  3. dirtwarrior17
    May 14, 2004
    1,820
    Redding, CA
    Yup... the front cts is hooked up and in the front of the manifold next to the thermostat... the leftover sensor doesn't seem to fit anywhere...
  4. tx_sub
    tx_sub 1/2 ton status
    Mar 5, 2004
    548
    Denton, TEXAS
    assuming your 88 block was fuel injected, it had two cts's. the one in the intake is for the computer iirc and the one in the driver side head is for the guage.
  5. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    The knock sensor should be on the passenger side above the oil pan. Coolant temp is in the front crossover and there is another sensor that goes into the head on the driver side. It goes into a waterjacket but I have no idea what it does. I run a 70s motor with TBI in my Suburban, I had to get adapters to put that sensor into my older style heads. Maybe thats the one you are having trouble with.
  6. dirtwarrior17
    May 14, 2004
    1,820
    Redding, CA
    yup... sounds like that the one... Can i use it on Camel humps?
  7. dirtwarrior17
    May 14, 2004
    1,820
    Redding, CA
    I haven't checked it this will fit yet but can i run it off the water pump or is that too far away from the heat?
  8. dyeager535
    26,975
    Single prong round connector=knock sensor
    Single prong (typically a nail head on the senor) is coolant sensor for gauge.
    Dual prong is CTS.
    Coolant sensor for the gauge really doesn't matter where it is, since it's relative, but it would look odd to have the gauge reading 150* all the time. Every head I've seen has been drilled/tapped for that sensor, although there are two different threads used, as mentioned, its easy to adapt.
  9. dirtwarrior17
    May 14, 2004
    1,820
    Redding, CA
    Can i run it out of the water pump plug? The camels don't look like they have a spot for a sensor.
