1988 Ram 250 good parts truck/deal???
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by fortcollinsram, Dec 26, 2001.
  1. fortcollinsram
    fortcollinsram 1/2 ton status
    Nov 8, 2001
    2,261
    Fort Collins, CO
    I found a 1988 Dodge 250 3/4T pickup in my neighbourhood for sale... It has a 360 V-8, a 5-spd manual... I need help Ding the axles...I think the front is a Dana 60...It has 10 diff cover bolts, and on the lower right side of the cover it sayes "60 F" and on the left side is the number "C37285"...What do these numbers mean...It also has "Dualmatic" hubs...whatever the hell those are..is that a problem? The rear axle looks to be the same but I couldn't find any casting numbers (but then again I didn't want to get on the ground in my good "morning- after-christmas-bruch clothes [​IMG]) Both look like full floaters though (the hub pokes thru the center of the wheel). So what do you guys think...? Any ideas where I can find info on this truck, things such as t-case, tranny and such? Thanks for you input....
    Chris
    Was that a speed bump? No, just a Rice Rocket </font color=red> <a target="_blank" href=http://coloradok5.com/gallery/fortcollinsram>My 87 Blazer</a>
  2. fortcollinsram
    Nov 8, 2001
    2,261
    Fort Collins, CO
    ANYBODY?
  3. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    That should be a D60 front (based on the 60F) but the hubs are junk, or so I am told. The back should be a D70 I think. At least it was on the diesels. To bad it's not a turbo diesel. You could swap in the diesel and 5 speed for a sweet drive train. I don't know that much about the old dodges but I think that front is usable on a GM (pads are about 3/4" off IIRC).
    That's about all I know (or think I know). I'm sure others know more.
    Russ
    85 K30 CUCV, 350 TBI, TH400, 205, D60/C14, 4.56 Locked
    Some day: 4" lift, 44" tires, massive cutting, shorter wb and rear overhang.
  4. fortcollinsram
    Nov 8, 2001
    2,261
    Fort Collins, CO
    COOL, keep the info rollin' in [​IMG] How much would it cost to have the spring pads moved on the axle? Thanks gang
    Chris
  5. tRustyK5
    Jul 23, 2000
    36,180
    1,388
    E-town baby!
    Send Michael a pm (77chev) he swapped in a dodge D60 front under his Chevy...
    Russ, wouldn't the 3/4 ton dodge have had a D60 rear? I don't know that much about them but a D70 sounds like one ton territory.
    Rene
    <a target="_blank" href=http://coloradok5.com/gallery/project_T2> tRusty pics...</a>
  6. michaelm
    michaelm 1/2 ton status
    Feb 2, 2001
    872
    my 70 is from a diesel 3/4 ton 1990-91
  7. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Yeah, the 3/4 ton diesels have D70, 1 ton diesels got a D80 I think, don't know about the gassers. Other than that @#$ D61 garbage, I gotta say that at least Dodge does better than GM on the axles. I mean, who had their head up their but when the D44/C10 was used as the front for 3/4 tons (even HD). As far as moving the perches, it's not hard on the driver's side. Only problem is that the passenger side perch is cast into the diff housing so it can't be moved without retubing or making some sort of an offset plate (not recommended) or machining.
    Russ
    Some day: 4" lift, 44" tires, massive cutting, shorter wb and rear overhang.<P ID="edit"><FONT class="small">Edited by BadDog on 12/26/01 07:32 PM.</FONT></P>
  8. tRustyK5
    Jul 23, 2000
    36,180
    1,388
    E-town baby!
    Cool, thanks for the info...
    Rene
