1989 454 tbi intake manifold question...
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 3car, Oct 10, 2003.
  1. 3car
    3car 1/2 ton status
    Dec 16, 2001
    976
    Hernando, Florida
    i have a 89 sub with a tbi 454.there seems to be an adapter plate that mounts the tbi unit to a 4bbl intake,with a coolant line running to it?i havent pulled it apart to verify this,but am i correct in my observation?is it just a quadrajet manifold under there? /forums/images/graemlins/confused.gif
  2. KRAZIE87K5
    KRAZIE87K5 1/2 ton status
    Feb 23, 2001
    3,369
    Chicago, IL
    AFAIK, YES its an adapter on top of a QJet intake! That preheater is important too! Be sure to use it!
    -Dan
  3. 3car
    3car 1/2 ton status
    Dec 16, 2001
    976
    Hernando, Florida
    cool,thanks.my next question would be...what does the preheater do?does it cool the air charge once the engine is up to temp,or is it there to raise the temp??? /forums/images/graemlins/thinking.gif
  4. fortcollinsram
    fortcollinsram 1/2 ton status
    Nov 8, 2001
    2,261
    Fort Collins, CO
    The preheater helps bring the engine to operating temps more quickley...
    Are you going to stick with the TBI or are you going to put a carb on it..The older style TBI intakes (like the one you have) are VERY restrictive...Edelbrock makes a nice TBI replacement intake mannie...
  5. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    The TB heater plate/adapter is there to prevent Icing. It keeps the throttle plates warm so Ice cant form on them an cause the throttle plates to stick open.I think it was a CYA thing GM did to the TBI BBCs because of all the air they could gulp down.
    It is possible for the plates to ice up even in temps above freezing when operated at or near WOT. The heater plate is there to stop that
