1989 - Leaking Sliding 1/4 Windows
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Glenn89, Apr 18, 2000.
  1. Glenn89
    Glenn89 Newbie
    Apr 18, 2000
    Hello -
    This is probably an age old question but I finally have a Blazer (1989) with sliding side windows. I've always liked the way those looked. Unfortunately, I learned that they leak the other day during a rain storm. The rubber gaskets appear good.
    Any help would be greatly appreciated.
    e-mail: lettang@attglobal.net
    Thank you,
    Glenn
  2. Espen88k5
    Espen88k5 1/2 ton status
    Feb 19, 2000
    981
    Norway
    There are some gutters on the bottom rail. I used a pipe-cleaner and cleaned the holes out. It stopped leaking.
    The water found a easyer route down, and did not seep through under the sliding-glass.
    [​IMG]<font color=blue>Espen88k5</font color=blue>
  3. smack
    smack 1/2 ton status
    Feb 24, 2000
    277
    Colorado
    I had the same problem also with good-looking gaskets. I took mine to a glass shop and they cleaned out the surface where the outside of the perimeter gasket met the shell and put some sealant in. Also, on the bottom channel they put in some sealant behind the slide. All this was done with out removing the window. No leaks. I think they charged me $20 bucks.
    Good luck.
