1990 350 sb tbi
Discussion in 'The Garage' started by wraenking, Mar 5, 2005.
  1. wraenking
    wraenking 1/2 ton status
    Apr 30, 2003
    1,493
    Toms River, NJ
    ok, we finished my buddies engine swap today. he drove her home, but she is sputtering a bit. firing order is good, and timing is good.
    what are some things we could check?
  2. hi pinion
    hi pinion 3/4 ton status
    Sep 25, 2003
    5,354
    **PLUMBING THE WORLD**
    Injector bad mabey? I might check to see if they are both pumping fuel good mabey :) ,good luck, jacob
  3. dirtwarrior17
    dirtwarrior17 Banned
    May 14, 2004
    1,820
    Redding, CA
    was the motor mild or stock? sometimes with a modified tbi motor you have to let the computer learn a new spark curve and fuel map.... after 48 hours it should run better if that is the case but if the mods are too much for the computer you will have to get a chip obviously...
    good luck.
  4. wraenking
    Apr 30, 2003
    1,493
    Toms River, NJ
    motor was a stock crate 350. i guess we better try to get a computer on her and see what it says
  5. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    was it a TBI motor? Or was it just a basic GM crate motor. If it was a basic crate motor for a carb application the cam does not work well with TBI
  6. dirtwarrior17
    May 14, 2004
    1,820
    Redding, CA
    Most crate motors don't come with the stock cam, tbi or carb... if it is still acting up after he has driven it for a week or so then let the troubleshooting begin. When i first started mine up after the swap it ran like crap for a week or so but i never got it out of my driveway. there were some little things like vacuum lines that were apart of it but it has a cam, manifold, flat tops, camels, headers, holley tbi, higher fuel pressure, and a couple other bells and whistles that threw the computer off... it runs and idles pretty good now but i still need to burn a chip for it.
