1990 blazer idle problems
Discussion in 'The Garage' started by santiago, Jun 16, 2005.
  1. santiago
    santiago Newbie
    Jun 16, 2005
    Detroit
    ok fellas i have a rough idle and surge i have already replaced plugs,wires,cap,mass air flow sensor,tps sensor,air idler valve,throttle body gasket,o2 sensor,air filter and i cleaned out the egr valve any advise would be a blessing thanks in advance :confused:
  2. Kiqman
    Kiqman 1/2 ton status
    Dec 14, 2004
    102
    Portland Oregon
    Rough idle and surge
    Looked at your fuel pump? Making enough pressure? Had a problem like yours and it turned out to be the in-tank pump. Just cut a hole above the tank in your bed to access the top of the tank. Beats pulling the tank out. You can test pressure at the TBI. Good luck.
  3. dyeager535
    26,982
    191
    Ever get any codes?
  4. sweetk30
    Nov 1, 2004
    25,552
    546
    horseheads , ny 14845
    first. what kind of blazer? s10 or full size. next what plugs for tune up? and last what motor.?
  5. who would do that
  6. pvfjr
    pvfjr 1/2 ton status
    Feb 10, 2004
    2,425
    Oakridge, OR
    Who would cut the hole in the floor?.....Lot's of people. You'd be surprised.
  7. jekquistk5
    jekquistk5 Weld nekid Premium Member GMOTM Winner
    Jan 18, 2004
    11,027
    855
    Pinckney, MI
    Check your EGR Solinoid. And check for vacuum leaks
  8. icer97
    icer97 1/2 ton status
    Jun 15, 2005
    116
    Missouri
    Sure sounds like vacume to me. Take a can of carb cleaner and spray all around. Could be a intake gasket leaking internally, ive found these by removing the oil fill plug on the valve cover and giving her a snort of carb cleaner.
  9. REDCRO_REDNECK
    REDCRO_REDNECK 1/2 ton status
    Apr 7, 2005
    241
    mo
    no body should if they have a short bed then you have a hole in your bed for nothing. The sender is under the cab (1987 shortbed).
  10. Kiqman
    Dec 14, 2004
    102
    Portland Oregon
    I've enjoyed the easy access a "trap-door" above the fuel tank provides. I wouldn't do it to a new rig but in my 89 it was a no-brainer. Just fabbed up a little hinge setup and seal. Once you throw the sound proofing and carpet back down you don't know it's there even standing on top of it. Lazy...yes but I've never heard anyone brag about the cargo capacity of their K5 anyway and taking those tanks out sucks. More time for mud and beer! :cool1:
  11. Tracktor
    Tracktor Registered Member
    Feb 24, 2005
    9
    Yacolt, Washington
    I know you've replaced the wires already, but I just went through this problem and thought I'd post my fix. It was a shorting plug wire. The cap was crocked at the plug and shorting on the heat shield. Wires were otherwise in great shape, but the heat had dried the caps out. ................
