1990 Jimmy, computer controlled???
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by loudandproud, Sep 26, 2000.
  1. loudandproud
    loudandproud 1/2 ton status
    Jun 27, 2000
    451
    Ham Lake, Minnesota
    I was wondering if a 1990 Jimmy had a computer controlling stuff on the truck? If so, what does it control?
  2. tRustyK5
    Jul 23, 2000
    36,170
    1,376
    E-town baby!
    Yes! The computer controls various engine functions. Mostly fuel mixture and ignition timing. It does this with an assortment of sensors; throttle position sensor, O2 sensor,coolant temp sensor, and a few others. The computer also has a self diagnostic feature that stores 'trouble' codes when one of the systems has an abnormal reading.
    Hope that helps
    Rene
  3. loudandproud
    Jun 27, 2000
    451
    Ham Lake, Minnesota
    Does the computer controll the speedometer??? Thanks
  4. GMC4by4
    GMC4by4 Registered Member
    May 10, 2000
    48
    Silver Spring, MD
    My '89 has a mechanical speedometer cable from the transfer case. But I've seen older GM cars with vehicle speed sensors (VSS) that run a lead from the speedo to the computer. The computer compares engine speed, O2 gasses, vehicle speed, mass air flow, etc and changes the mixture according to these stats. Most of the newer cars shift the transmission based on VSS input and engine RPM. So what I'm trying to say is because there's no VSS I'd have to see the schematics to see if there is a lead from the speedo to the computer. What are you trying to figure out?
    -Rick
  5. River
    River 1/2 ton status
    May 8, 2000
    121
    Amstelveen, Netherlands
    I also have a `90 K5 and the speedometer is electronic driven. I don`t know if you can adjust it by computer. I have seen solutions to recalibrate the speedo, can`t remember where do. I will look it up see if a can find it again.
    Greetings from AMsterdam,
    River `90 K5, 350, TH700R4, NP241, "33, 3.08, 10 bolt F, 10 Bolt R(GOV-Lock)
  6. CK5
    May 19, 1999
    21,623
    701
    CO
    I have had my speedo recalibrated (90 K5) a few times, they change out small plastic gears under the dash, wasn't looking that close at the time or I could tell you more.
    5,000 Pounds of American Rolling Steel
