1990 K5 Vibration at Moderate Speed
Discussion in 'The Garage' started by allamericanmale30, Feb 11, 2006.
  1. allamericanmale30
    allamericanmale30 Registered Member
    Feb 11, 2006
    5
    Verona, Missouri
    What would be the likely cause of vibration at my intermediate to rear portion of my drive train at roughly 55 to 65 mph? I replaced the u-joints and noticed there is a small notch where the u-joints seats into the rear drive shaft, could that cause vibration?
  2. johnathan
    johnathan 1/2 ton status
    Sep 26, 2005
    376
    Ocean Springs,MS
    i have always had vibe issues with my k5.My advice would be t stick it in nuetral on flat ground p brake applied and grab the rear shaft. anyup-down side-side movement and somethin should be done.If its an auto tranny check the slip yoke.Any modifications been done to your rig ,lift,big tires etc.?and by the way my 84 k5 still has some vibes at high speed,just an old truck for ya
  3. allamericanmale30
    Feb 11, 2006
    5
    Verona, Missouri
    It's pretty much stock, I had to replace the rear-end about 3 months ago with one from a salvage yard. It looked good and was a match to the front. I have it all tore down trying to figure out what is going on.
  4. johnathan
    Sep 26, 2005
    376
    Ocean Springs,MS
    did it do that with the old rearend?
  5. allamericanmale30
    Feb 11, 2006
    5
    Verona, Missouri
    not at all, could it be caused by the u-joint housing piece having a chip in it?
  6. johnathan
    Sep 26, 2005
    376
    Ocean Springs,MS
    i have swaped a 14 bolt in mine it has a chunk missing like your talkin about, no problems though. does the u-joint seat tightly?
  7. allamericanmale30
    Feb 11, 2006
    5
    Verona, Missouri
    Yeah it seats in there tightly, think I can just rotate the rear drive shaft 180 would help?
  8. johnathan
    Sep 26, 2005
    376
    Ocean Springs,MS
    yeah could be outa phase.don't give up persistance pays off good luck man
  9. roadnotca
    roadnotca 3/4 ton status
    Sep 16, 2005
    5,433
    Redondo Beach, CA
    Check/balance the drive shaft.(?)
