1990 pressureplate to flywheel bolts
Discussion in 'The Garage' started by nerraw117, Mar 20, 2007.
  1. nerraw117
    nerraw117 1/2 ton status
    Jan 5, 2005
    788
    charlotte, NC
    anyone know what size the pressure plate to flywheel bolts are? im doing a tranny swap and have no clue on shank, length or tpi. thanks.
  2. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    I want to say 3/8-16 x 1 inch , but need to double check , that may be too old , could of gone metric by 1990.
    Search pressure plate bolts on Summit . They have them listed for everything . In a small block in 1990 , I was correct .
  3. nerraw117
    Jan 5, 2005
    788
    charlotte, NC
    thank you. very much. sorry i didnt think they would five you the exact size of them. sorry. will know next time. i knew i renewed my membership again for something lol.
  4. sweetk30
    Nov 1, 2004
    25,539
    539
    horseheads , ny 14845
    you need flex plate / fly wheel bolts specificly. the std bolts heads are to deep and will hit stuff. i just pulled a 4 speed cause some dumby used std store solts. the heads were to tall and hit the clutch disk all the time. found it was the noise we were lookin for.
    napa/autozone /advanced can all get you a mr. gasket kit of bolts or napa has them in there own packets.
    flywheel bolt pack napa 6151554
    summit search for ya. both sets. http://store.summitracing.com/egnsearch.asp?N=700+115+303524&D=303524
  5. nerraw117
    Jan 5, 2005
    788
    charlotte, NC
    read real carefully what i was saying. i do not need the flywheel bolts. i need the bolts that bolt the pressure plate to the flywheel. your talking about the bolts that bolt the flywheel to the block.
  6. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    Also, pressure plate bolts are special and not the same as store bought bolts. Pressure plate bolts have a special shoulder on them that help center the plate correctly.
  7. nerraw117
    Jan 5, 2005
    788
    charlotte, NC
    so ones threaded the whole way wont work? i dont know who would sell them local. :(
  8. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    Nope, not correctly anyway. Your local auto parts store should carry them. If not try the dealer or just order them from Summit Racing.
