1990 Steering Wheel on 1988 K5
Discussion in 'The Garage' started by Irish Wake, Feb 15, 2007.
  1. Irish Wake
    Irish Wake Registered Member
    Jan 15, 2007
    44
    Georgia
    I got a late model steering wheel to install on my '88 K5. It has the wheel, center cap and a wire with a spring and brass mushroom on the end. How do I install this wheel and am I missing any parts?
  2. 73k5blazer
    Dec 28, 2001
    4,987
    38
    The Rustbelt
    It should bolt straight up.
    Is there a wheel on your '88 right now? If so, just pay attention when you take it apart, it's very straightforward.
  3. skyyk5
    skyyk5 1/2 ton status
    Jan 2, 2007
    1,537
    N.E. PA
    Have your old steeringwheel straight, take the nut off, and pull the wheel. (steeringwheel puller)Put the new wheel on, tighten the nut down. done
  4. Irish Wake
    Jan 15, 2007
    44
    Georgia
    Thanks, How do I make sure the horn will work? Where does the wire with the spring and brass contact go? Is the horn set up the same as the old stock wheel? Thanks
  5. Irish Wake
    Jan 15, 2007
    44
    Georgia
    Anyone got a exploded view of the steering/horn assembly?
  6. goldwing2000
    goldwing2000 Guest
    It's all the same. Like has been said, just pay attention as you're taking it apart and re-use whatever you don't have new.
  7. Irish Wake
    Jan 15, 2007
    44
    Georgia
    Thanks Everyone!
