1990 Suburban starts, runs fine for 30-45 seconds, then dies. Need Help
Discussion in 'The Garage' started by joey90, Dec 17, 2003.
  1. joey90
    joey90 Registered Member
    Dec 9, 2003
    32
    I have a problem with my 1990 Suburban. It has a newer 350 in it with 20k.
    When I go to start it the thing starts up fine, no throttle needed or anything, just turn the key. It'll run like normal for 30-45 seconds then it just shuts off. Doesn't seem like it dies, but rather shuts off, as if you switched off the key. It leads me to believe it may be an electrical problem but I have no idea. When I start it up the check engine light doesn't come on, so I don't know if it's throwin a code or not.
    Any suggestions?
  2. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    Check for plugged vacuum line to the MAP sensor. Will the truck run if you give it gas? Once it dies does it start right back up again?
  3. joey90
    Dec 9, 2003
    32
    I'll check that. I give it gas and it revs like normal. I keep it rev'd and it still dies in the same ammount of time. Once it dies it does start right back up again, usually...
  4. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    Also check for proper functioning EGR valve.
  5. joey90
    Dec 9, 2003
    32
    how do i check to see if it's functioning properly?
  6. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    Start by taking the vacuum line off the EGR valve and then hook a vacuum pump to it and see that it does open. If it is stuck open then you need to remove it and either try to clean it or just replace it. The EGR valve on your truck is operated through an electric vacuum switch so there is also possibilities of the switch being bad also (but I doubt it)
  7. Klink K5
    Klink K5 1/2 ton status
    Aug 3, 2002
    549
    Northwest Iowa
    This maybe your problem.
  8. joey90
    Dec 9, 2003
    32
    Thanks guys, I'll check these tomorrow. Please keep the ideas coming!
  9. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    That info is not correct. The fuel pump relay is what gives power to the fuel pump. The pressure switch is there in case the fuel pump relay should go bad so long as there is oil pressure it then gives power to the fuel pump. I would however make sure you can hear the fuel pump cycle for 2 seconds after the key is turned to the on position.
  10. joey90
    Dec 9, 2003
    32
    someone was telling me i could remove the air filter and look to see if fuel was being sprayed, is that true?
  11. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    That is correct.
  12. tRustyK5
    Jul 23, 2000
    36,170
    1,379
    E-town baby!
    It could just be a plugged fuel filter. That happened to my wife's old Mustang /forums/images/graemlins/blush.gif I thought the fuel pump had packed it in. It would run for 30 seconds or so and then just die...in no time at all it would fire back up but wouldn't run longer than 30 seconds.
    I installed a new filter and it ran like a charm again.
    Rene
  13. big pappa b
    big pappa b 3/4 ton status
    Jan 3, 2003
    6,328
    Falcon, Colorado
    same thing happened on my old S-10. replaced the fuel filter and good as new
  14. K5DRAGER
    K5DRAGER 1/2 ton status
    Jul 27, 2001
    1,164
    Momence, IL
    Just throwing this out there because it happened to me on my 88 tbi crew cab. I redid the wiring to the alternator, because the previous owner had it all messed up. When I was done I drove to my budy's house... about 10 minutes and messed around for a while. When I went to leave it did what yours did it would run for about 30-45 seconds and just shut off. After alot of trouble shooting and about an hour later we found one of my new wires I had fixed with a crimp/solder type connector didn't make a good connection. I guess that when the computer saw the low battery/ voltage it would shut off the truck. And would only let you restart it if you turned the key all the way to off and then started it. We fixed the wire problem and it started right up and stayed running.
  15. joey90
    Dec 9, 2003
    32
    The Burb is runnin again!
    I didn't have time to check it out myself but my dad fixed it. It was either the fuel pump or the injector relay. Replaced em both and it runs just fine! Thanks alot for all your help guys, it's appreciated.
