1991 14 bolt FF
Discussion in 'The Garage' started by suntadz, Feb 12, 2007.
  1. suntadz
    suntadz 1/2 ton status
    May 15, 2005
    187
    bay area, ca
    Hey- Ive done some research and it seemed to me that this would fit a 1987 truck but would take some modifications. I also wasnt sure if these years were a FF or SF. I had a guy on the phone claim it was a direct bolt up to my truck and a FF out of a 1991 3/4 ton truck. When i told him i wasnt sure if it was FF and didnt think it was a direct fit he kinda got mad at me and told me I didnt now much about chevy trucks. (which is true but he doesnt know that). Anyway I was looking for a 14 FF direct fit for my truck and was under the impression a 1973-1981 3/4 would be a direct fit. Trying to do so without being ripped off either. I do not know how to weld and was trying to do it all in the driveway so a direct fit was kinda important to me. Can anyone let me know if I am wrong? This guy kinda rattled me and made me doubt myself. thanks
    robb
  2. WRENCH-HEAD
    WRENCH-HEAD 1/2 ton status
    Dec 25, 2005
    327
    Littleton, CO
    It could be either a full float or semi-float in that year. As for the direct fit, no. That is out of an IFS era rig and the spacing of the spring perches and shock mounts are probably different.
    Edit: If it is a 91 suburban you set, as those didn't change until 1992.
  3. suntadz
    May 15, 2005
    187
    bay area, ca
    cool. thats what i was thinking. thanks for the assurance
    FX
  4. BigEasy
    BigEasy 1/2 ton status
    Dec 18, 2006
    418
    U-jeen, Oragun
    In 1991, it could be out of a 3/4 ton Suburban, 1 ton crewcab, or 3/4 or 1 ton newer bodystyle pickup. Out of the 3, the only one that will be a direct bolt-in is the one from a 3/4 Suburban, BUT it will be a 14sf, NOT a 14ff. The guy was trying to hose you. Look elsewhere.
  5. littlejimmythatcould
    littlejimmythatcould 1/2 ton status
    Feb 6, 2006
    797
    Clovis, NM
    Not meaning to hijack, but would a 14 bolt axle out of a 95 pickup be a FF? How can you tell if it is?
  6. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    A 2wd could easily have the 14ff.
    The 88+ IFS trucks used the FF with the 454 or 6.5TD in 3/4-tons, and (obviously) the 1-tons.
    Full-float:
    semi-float:
  7. BigEasy
    Dec 18, 2006
    418
    U-jeen, Oragun
    I agree they can be found in either a 4wd's or 2wd's. I never said 4wd's only. :wink1:
  8. u2slow
    May 9, 2001
    2,217
    BC Canada
    Sure... I meant the 3/4 ton Suburban bit. ;)
  9. BigEasy
    Dec 18, 2006
    418
    U-jeen, Oragun
    Ok, now you're just screwing with my head. :p:
  10. Chrisblazzer89
    Chrisblazzer89 1/2 ton status
    Oct 12, 2006
    1,966
    Massachusetts 02301
    Just look for a 79 k30 pickup and that would bolt right in.
  11. dbreid
    dbreid 1/2 ton status
    Dec 26, 2005
    379
    San Mateo CA
    I know that the FF is obviously preferable (not just the full floating portion, but the extra size on the Ring gear), but is the Semi FLoat 14 bolt worth keeping? How does a Semi Float compare to, say a 44 rear or an 8.8? I know you can get lockers for both.
    Thoughts?
  12. suntadz
    May 15, 2005
    187
    bay area, ca
    I thought the k30 had different shock or spring mounts I would have to alter but the k20 would be the only one to bolt right up.
  13. Chrisblazzer89
    Oct 12, 2006
    1,966
    Massachusetts 02301
    Well I have a k30 14BFF rear on my truck that was a bolt on to my 88 blazer
