1991 BLZR In need of Timing Mark
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by gumneck, Mar 7, 2003.
  1. gumneck
    gumneck Registered Member
    Feb 6, 2003
    89
    VA
    Hello, As my subject reveals, I am in need of timing mark for stock 350 EFI on 1991 Blzr. The vehicle emissions label is not under the hood as you might suspect.
    Tks in advance.
    tom
  2. Grim-Reaper
    7,385
    Atlanta
    Do you need the degrees to set it at or do you need to know where you look to set it?
    Your wording is a little confusing.
    GM only put the scale in two places as far as I know on the SBC's that went into trucks. Some are to the right of the right leg of the water pump (standing in front of truck facing engine (driverside) and some you have to look behind the water pump between the front of the block to see the timming tab.
    Most SBC's recomend 8degres befroe TDC but with your truck being FI I'm not exactly sure of the correct porcedure needed to set base timing. The FI regulates it on that vehicle. I know there is something that has to be disconnected of Jumped to get an acurate reading at the crank.
    If your trying to cure a knock problem with the timing you probably have a bad Knock sensor and the problem is that and not actual a timing adjustment problem.
  3. BigRed89
    BigRed89 1/2 ton status
    Oct 28, 2002
    223
    Los Angeles, CA
    I think Grim explained very well where you can find the timing mark/pointer. As for setting the timing, check out this post which discussed finding the wire you need to disconnect prior to setting the timing. Your timing needs to be set to 0 degrees.
  4. Rolled
    Rolled 1/2 ton status
    Jun 16, 2002
    683
    Anchorage, Alaska
    In addition, I always put a little white-out on the mark. This makes it alot easier to check it.
  5. gumneck
    Feb 6, 2003
    89
    VA
    Sorry about the confusing vagueness(sp). I needed the degree. I found out by calling some 1800 Chevy service number and they told me 2 degrees btdc. My local chevy dealer service dept. wouldn't tell me. So f him right. Anyway, I just need to set it proper b/c I've been using the truck with just the manual advance/pullback hand method. Its working just want it right b/c I'm anal like that. Thanks for reading my help request and responding.
    Tom
