1991 Jimmy Specs
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by MUD E1, Nov 21, 2002.
  1. MUD E1
    MUD E1 Registered Member
    Nov 17, 2002
    6
    WA
    I've done some searching and want to be sure I've got things right. Is the following information correct for a stock 1991 full-size Jimmy?
    1) GM 10-bolt front and rear
    2) Limited slip in rear
    3) Gears identifiable with these codes:
    GU2 = 2.73
    GU4 = 3.08
    GU6 = 3.42
    GT4 = 3.73
    GT5 or GT8 = 4.10
    G80 = Gov-lock
    4) 4L60E transmission (for automatics)
    5) TBI 350 V8 with 210hp/300ftlbs
    6) Automatic locking hubs in front
    7) NP241 transfer case
    8) 1/2 ton suspension
    9) Front disc brakes
    Also, what size are the stock aluminum wheels with holes in them? 15x8?
    Thanks for any help!
    Brent
  2. txbluethunder
    txbluethunder 1/2 ton status
    Jan 29, 2002
    835
    Austin, TX
  3. MUD E1
    Nov 17, 2002
    6
    WA
    Thanks, txbluethunder. That page is where I began my search. It helped answer a few points.
  4. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> It looks like those specs are right with the exception of the tranny. It should have a 4L60, not the 4L60E. The only difference is that the E is electronically controlled, they didn't come out until a bit later. </font color>
  5. sdavid
    sdavid 1/2 ton status
    Aug 5, 2002
    244
    Livingston, TX
    I think your wheels are going to be 15x7. Check your driver's side door above the latch w/ door open. It should tell you there.
  6. Muddin_Mavric
    Muddin_Mavric Registered Member
    Jun 28, 2001
    55
    Centeral WI
    i bought a set of those stock aluminum rims and they are 15x7
    Justin Behr
