1991 K-5 Fuel Injection
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by PGL4VT, Aug 5, 2002.
  1. PGL4VT
    PGL4VT Registered Member
    Feb 10, 2002
    71
    Roanoke, Virginia
    1991 Fuel Injection. Seems to be running really rich. Heavy smell of gas especially when first started. Lots of black soot in exhuast and blows black smoke when floored or under heavy load. How can I fix this? I'm used to simply adjusting the carb on my 72 K-5 but I know very little about this set up. Help! Thanks, Pat.
  2. fr8train
    fr8train 1/2 ton status
    Aug 2, 2000
    1,712
    Maryland
    TPS( throttle postion sensor) could be funny, also check you O2 sensor.
  3. BurbinOR
    BurbinOR 3/4 ton status
    5,829
    Oregon
    1. Get a scanner..........like one from www.autoxray.com - cost about $150 - GOTTA have a scanner if you're running FI. Also go to this page GM Computer Codes and print it out. Gonna need it someday, even tho you aren't having codes now. /forums/images/icons/tongue.gif
    2. Read, read, read all you can about FI on www.thirdgen.org - then read some more.
    3. Get a book like 'Chevy Fuel Injection' or something like that by Ben Watson - sorry, have three books, all are loaned out and I can't remember the names. /forums/images/icons/crazy.gif
    4. Sounds like your O2 sensor is done, or your injectors are in need of cleaning. www.cruzinperformance.com can do them for cheap. Check your fuel filter while you're at it..........
    5. Check your TPS setup - thirdgen has a tech article on how to set it.
    Hope this helped ya!
  4. PGL4VT
    Feb 10, 2002
    71
    Roanoke, Virginia
    BTW, I replaced the O2 sensor with a Bosch already and I just got a new fuel filter tonight.
  5. dyeager535
    26,980
    Don't start throwing money at parts, or you will quickly exceed the cost of the scanner that BlazzinOR mentioned, which will *save* you money in the long run.
    Get yourself a factory service manual while you are at it, scanner data doesn't mean anything if you don't know what you *should* be seeing number-wise.
