1993 Blazer K1500 Silverdado
Discussion in '1992-Present Chevy & GMC models' started by elfoisland, Jan 28, 2002.
  1. elfoisland
    elfoisland Newbie
    Jan 28, 2002
    Hi, I was wondering if you can help me:
    I've just purchased a 1993 blazer K1500 Silverado, 84k miles,, I'm not any heavy off-roaderneither an expert but I frequently use 4x4 in heavy rain here in Miami and a few times an some "light" trail.
    The truck is standard from the factory it has not any modifications.
    This will be my first Chevy truck and the only literature I found on the web were not really encouraging, I found few reports stating various problems including the ones on the transmission on the pre-1995 Chevy trucks, nevertheless I had a good deal and I bought it today.
    Do you have any suggestions?
    Which size of tire can I put without modifying the lift?
    Any idea in how to put the spare tire outside and save a lot of space?
    Thank you very much for your attention
    Fabio
  2. dhcomp
    dhcomp 3/4 ton status Premium Member
    Mar 17, 2001
    9,862
    294
    Truckee, CA
    Hey, congrats on the purchase. I have a 94 K1500 blazer with about the same miles. I've heard the following about tires.....(from AJMBLazer)
    "285/75R16 (33x11.25R16) and 255/85R16 (33x10R16) fit on the stock rims or aftermarket 16x7's with the same 5.25" backspacing as stock without any rubbing. If anything, all you will need to do is trim the black plastic air dam that hangs below the bumper a little on the edges.
    305/70R16 (33x12R16) and 295/75R16 (33.25x11.6R16) will fit without rubbing also, but it would be good to put them on the OEM 16x7 rims (not the work truck steel rally wheels in other words, but I doubt your Blazer has those) or aftermarket 16x7 rims with the same 5.25" backspacing, and they MAY require about 1-1.5" of torsion bar cranking from the stock settings. This is perfectly normal and within safe limits. There are people on this board that run all these different tire sizes on their 1/2 ton 4x4 IFS trucks without any problems. Good luck. I personally like the 285/75R16's myself, but whatever you want, it will work. Keep your gearing in mind though."
    I know that they make external swing out type tire carriers, but i think they are a hassle and personally think they look terrible. I'm not sure what your height limits are, but i'd definitely consider upgrading the roof rack and getting a roof top spare carrier before i put it on teh back. good luck!
    Darren
    <a target="_blank" href=http://members.cardomain.com/dhcomp>http://members.cardomain.com/dhcomp</a>
  3. MudNurI
    MudNurI 1/2 ton status
    Jul 15, 2001
    2,113
    VT
    You can run 16X8's and 305/75/16's WITH NO mods,,,, and I mean NONE!!!
    I had them on my suburban- it was a 94- same exact thing as your 93- however your just missing a few feet! LOL
    Good luck with the rig- hey--- any interest in selling me the seats out of it?? LOL I want them bad!!!!!
    Brandy
    LOVING the new Duramax!!!
