1994 chevy no fuel : (
Discussion in 'The Garage' started by HELLBENT DESIGNS, Sep 20, 2006.
  1. HELLBENT DESIGNS
    HELLBENT DESIGNS 1/2 ton status
    Apr 2, 2005
    453
    bozeman mt
    hey all quick question. i have a 1994 chevy z71 with the 5.7l. yesterday i go to start it ......nothing, it turns over fine has spark, but no fuel. i poured a bit of gas in carb and it starts right uo and runs till the fuel i poured in in used. i checked the underhood fuse which seems fine and pulled the fuel feed line off tbi and nothing. would this be for sure fuel pump:dunno: of course i just filled the tank before this happened! i know nothing of fuel injection rigs, so any help would be much appreciated thx:D
  2. b454rat
    b454rat 1/2 ton status Premium Member
    Jan 21, 2003
    3,009
    7
    Binghamton NY
    Yep fuel pump. Have fun!!!! Been there done that twice.
  3. HELLBENT DESIGNS
    Apr 2, 2005
    453
    bozeman mt
  4. 1979jimmy350
    1979jimmy350 1/2 ton status
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    before you go replacing the fuel pump you might want to make sure it is the fuel pump and not a relay or bad wire.
  5. diesel4me
    Jul 24, 2003
    17,570
    943
    Massachussetts
    module too!
    The ignition module controls both spark AND fuel injector pulse on most later GM trucks with fuel injection..It's entirely possible for only one portion of the module to fail and the other still work fine (no spark,but the injectors fire,or the spark is fine,but no injector pulse)..
    I've replaced several that were that way..usually a fuel pump dies gradually,but not always..I'd suspect the module and have it tested at a parts store before pulling the tank,and also the relay and wiring as already suggested,if this happened suddenly..(use a test light to see if 12V is getting to the plug on the fuel pump,or the wire if the plug can't be reached..)
    I helped my friend pull a tank out of a truck and replace the fuel pump not long ago--and when we were done,it still refused to start!--so he puts in a "good used" module we saved from another truck we scrapped..it still won't start!..then I checked the fuses,and the "ECM" fuse was blown!..OOPS!:doah: --don't do a lot of work for nothing,like we did!..:(
