1994 k2500 ext cab SAS????
Discussion in 'The Garage' started by original balzer, Dec 16, 2006.
  1. original balzer
    original balzer 1/2 ton status
    Nov 17, 2004
    4,660
    roosevelt utah
    my dad has a 94 gmc 2500 ext cab with 260k+miles on it and its kinda worn out. but the body is in desent shape and i can get it from him for a song. my question is is it possible to SAS with a chevy d60 if i change the x-case too or will the floor shape cause problems? also theres a few differnt kits to do SAS. is any particular kit better than the others or would a custom built with long leaves be better?
    balzer
  2. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    check the IFS forums on this site. yes, it can be done. IIRC b454rat has done it, as well as a couple others
  3. b454rat
    b454rat 1/2 ton status Premium Member
    Jan 21, 2003
    3,009
    7
    Binghamton NY
    If you want to change your t-case you can run the GM60. I had a divorced case, so mine wasn't directly under the floorboard. If there is any clearance problems, nothing a Ford tool can't take care of. There are a bunch of kits out there, but I think it's a toss up as to which is better. The Sky kit looks good, and the price definitly makes it look better. Not sure about the 6" lift over stock with just the brackets.
