1994 sub c1500
Discussion in '1936-Present Suburban' started by parker, Nov 16, 2004.
  1. parker
    parker Registered Member
    Apr 14, 2004
    40
    az,
    having part throttle miss under load seems fuel related any suggestions just had the plugs wires cap and rotor replaced. /forums/images/graemlins/1zhelp.gif
  2. bigred81
    bigred81 1/2 ton status
    Dec 5, 2003
    323
    Falls City,TX
    Check the fuel filter on the frame. Do you know how many miles are on the fuel pump in your sub. If high mileage it would be a good idea to put a new GM pump in. Might check the egr because it will also cause a part throddle miss if going bad but it will normally turn on the check engine light. Hope this helps out some.
    bigred81
  3. parker
    Apr 14, 2004
    40
    az,
    thanx 386,000 miles
  4. parker
    Apr 14, 2004
    40
    az,
    fuel pump and new filter in has better pick up
    still has miss /forums/images/graemlins/confused.gif
  5. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    Checkboth the EGR and the O2 sensor.
  6. parker
    Apr 14, 2004
    40
    az,
    egr bad replaced miss gone most of the time now
    /forums/images/graemlins/waytogo.gif
  7. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    thanx 386,000 miles
    Wow! I suddenly feel a LOT better about our '94 Sub having 132K miles on the clock. It's still got at least 250K left in it! /forums/images/graemlins/yikes.gif /forums/images/graemlins/thumb.gif /forums/images/graemlins/peace.gif /forums/images/graemlins/waytogo.gif /forums/images/graemlins/woot.gif
