1995 C1500 spindle nut torque procedure?
Discussion in 'The Garage' started by divorced, Jan 31, 2005.
  1. divorced
    divorced 3/4 ton status
    Jul 20, 2004
    5,115
    I'm putting new brakes and bearings on my 1995 C1500 and was wondering if anyone knows the torque procedure (with a Ft. Lbs. value) for the spindle nut?
  2. POWERMAD
    POWERMAD 1/2 ton status
    Mar 4, 2001
    3,466
    Oregon
    After packing the bearings with grease and installing the inner bearing and seal install the hub, install the outer bearing, washer and nut.
    while rotating the hub in a foward direction torque the nut to about 12ft lbs.
    Keep doing that a few times to ensure the bearings are seated.
    back the nut off till it is just loose then using your hand(not a socket) tighten the nut untill it is snug. If the cotter key hole does not line up loosen the nut slightly until they do.
    From the hand-tight position the nut should not be loosened more than one half flat to to install the cotter pin.
  3. divorced
    Jul 20, 2004
    5,115
    Sounds easy enough, thanks!
  4. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    always torqued to 25 ft/lb, backed off 1 turn, torque to 15 ft/lb, back off 1 turn, then torque to 7 ft/lb and back it off enough to line up the cotter pin. havent had a problem yet.
  5. BlueBlazer
    BlueBlazer 1/2 ton status
    Feb 15, 2001
    1,940
    Good to hear people doing things like this the right way. Your buddy Tim would laugh at you for using a torque wrench to do wheel bearings.
