1997 K3500 Dually
Discussion in 'The Garage' started by 87BrnRsd, Mar 29, 2005.
  1. 87BrnRsd
    87BrnRsd 1/2 ton status
    Apr 21, 2003
    2,457
    Boone, North Carolina
    4x4 will not engage for front drive
    dealer sold me new actuator, not the fix
    chevy dealer order new harness but must splice new harness to ???? no directions. Did not buy new harness.
    4x4 does not engage FRONT drive wheels, back wheels engage as expecteed
    no lights on shifter an expected in the lever on floor.
    The actuator looks the same as the original.
    The wiring harnes has the same connection for the ACTUATOR but an additional 2-pin connector that should go somehwere. Surmize, wrong harness for my axle.
    Raised truck, all positions of transfer case work as expected 2WD, 4HI, 4LOW, front driveshaft turns as expected
    Any help is appreciated
  2. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    the actuator was redesigned. the dealer should have known to sell you the harness with the redesigned actuator. sounds like they just dropped the ball.
  3. 87BrnRsd
    Apr 21, 2003
    2,457
    Thanks a ton!
  4. Pookster
    Pookster 1/2 ton status
    Nov 21, 2000
    3,195
    NYC, NY, USA
    Might also be worth it to get the 4x4 posi unit. Slightly more work, but a whole heck of a lot more reliable. (And you also get 2wd low gear if you needed to move something silly....
