1997 tahoe .Running rough..ses light on
Discussion in '1992-Present Chevy & GMC models' started by bckinblk, Mar 13, 2004.
  1. bckinblk
    bckinblk 1/2 ton status
    Jun 12, 2002
    305
    bristol connecticut
    I started it yesterday and it ran rough .Like its skipping.Ses light stays on..I can't find anything wrong ..Oil looks normal ..all plugs seem good..Is there a way to jumper pins like my 88 k-5 .?? Thanks for any info...
  2. marine_enlisted
    marine_enlisted 1/2 ton status
    Sep 29, 2002
    658
    Stafford, VA
    You have to have a OBDII code scanner to get codes and trun off SES lamp on your ride. Autozone will pull your codes and reset the lamp for free. /forums/images/graemlins/thumb.gif
  3. bckinblk
    Jun 12, 2002
    305
    bristol connecticut
    Cool thanks for the help.. /forums/images/graemlins/thumb.gif
  4. bckinblk
    Jun 12, 2002
    305
    bristol connecticut
    I went to auto zone and had it scanned .It threw 3 codes 2 for number 5 cyl misfire and 1 for tps low..So I replaced the tps and put in new plugs and wires .And it still runs like [darn]..I also noticed that the temp gage is running hotter than usual and it smells like antifreeze..What else could it be??? Thanks again... /forums/images/graemlins/confused.gif
  5. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    Sounds like a blown head-gasket. You're probably getting coolant in the #5 cylinder and thus the hotter running-temp, anti-freeze smell, and crappy performance.
  6. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    It could be as simple as a leaking intake manifold gasket allowing coolant into the cylinder. The Vortec 350's are infamous for that little design "feature". /forums/images/graemlins/frown.gif
  7. bckinblk
    Jun 12, 2002
    305
    bristol connecticut
    After days of research that is what I am thinking is the problem...The only dilemma I see is those new style fittings at the end of the gas lines and water spout in the intake manifold..What is the best way to remove them without destroying em??Anyone know??
  8. bckinblk
    Jun 12, 2002
    305
    bristol connecticut
    I just bought the new gaskets and a new fuel pressure regulator .I will install them sometime this weekend..Thanks for the help... /forums/images/graemlins/thumb.gif
  9. bckinblk
    Jun 12, 2002
    305
    bristol connecticut
    Update..Ok today I took apart the upper and lower intakes.I found that indeed the gaskets were leaking in 2 spots so that takes care of my antifreeze leaks.But inside the plenum there is a spider looking thing that has the fuel injectors coming off of it .All the injectore look clean exept for # 5 is dirty and blackened ..This is my misfire problem I bet..But what the hell is this thing called?? Do I have to change the whole unit or can I just change #5 wire?? Thanks again for any info in advance.. /forums/images/graemlins/thumb.gif
  10. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    injector harness?
  11. bckinblk
    Jun 12, 2002
    305
    bristol connecticut
    Cool thanks..The only thing I need now is the correct bolt pattern and torque specs and I should be able to put it back together by the weekend..Thanks again /forums/images/graemlins/thumb.gif
