1999 Silverado 1500 leaking water
Discussion in 'The Garage' started by abvgrndsub, Nov 29, 2006.
  1. abvgrndsub
    abvgrndsub Registered Member
    Jan 11, 2005
    20
    Fresno,CA
    My truck is leaking water between the firewall on the right side of the truck. I can't see exactly where its coming from so I think its the heater core. It doesn't leak allot but enough to know there is a problem.
    Is this something that can be fix in a home garage with general tools or do I need to take it to a mechanic. I did the heater core on my 75 blazer but this looks to be a challenge. Any advice appreciated.
  2. cjjones
    cjjones 1/2 ton status
    Feb 20, 2006
    111
    To the north
    R U sure that it isn't your AC condensor with condensation from use? Or is the water actually antifreeze coolant??
  3. gmc4cw
    gmc4cw 1/2 ton status GMOTM Winner
    Jul 19, 2006
    3,907
    west chester, Pa
    when does it leak? all the time, after running the A/C, or when its raining. three different problems.
  4. obijuan
    obijuan 1/2 ton status GMOTM Winner
    May 18, 2006
    4,009
    San Antonio TX
    if its antifreeze. use stop leak and trade it in.
  5. abvgrndsub
    Jan 11, 2005
    20
    Fresno,CA
    It only leaks if the air or heater is on. I was hoping that is was condensation but its coming thru the welds of the bottom of the firewall. I think I've only seen water dripping from that silver condesor unit in the past.
  6. Jishory
    Jishory 1/2 ton status
    Jan 8, 2002
    1,367
    Palmdale, CA
    is it water or coolant?
  7. Confedneck79K30
    Confedneck79K30 3/4 ton status
    Oct 1, 2006
    5,384
    LA
    that's a heater core most likely, but you need to really get under it and take a look for sure, or have a good mechanic friend look at it maybe?
