1999 Siverado - Service 4WD warning
Discussion in '1992-Present Chevy & GMC models' started by BorregoK5, Dec 18, 2002.
  1. BorregoK5
    BorregoK5 1/2 ton status
    Sep 7, 2001
    2,457
    San Marcos, Ca USA
    I've got a 99 Silverado 4x4 that intermittently brings up a Service 4WD warning. GM is stumped, no apperent rhyme or reason and nothing seems to be failing or wrong. Anyone else experience this?
  2. MudNurI
    MudNurI 1/2 ton status
    Jul 15, 2001
    2,113
    VT
    do a search at www.thedieselpage.com under the 2500 tranmsission/drivetrain section...if I remember correctly- there was a few over there with this problem-
    Brandy
  3. nash69
    nash69 Registered Member
    Mar 18, 2002
    24
    nj
    I had that pro once on mine. I believe there is some sort of redisgned fluid for the trans and xfer case. least thats what they told me. thye seem to be a reputable dealer though so i venture to say you should ask about it.
  4. DuneRunnersDad
    DuneRunnersDad Registered Member
    Apr 5, 2002
    14
    DuneRunners House
    Had mine replaced on my '01 a couple months back under warrenty. Dealer said this happens all the time. Something about a low volt/amp type thing from the BAD SWITCH that prompts the computer to display the "Service 4WD" to pop up. Same thing happened to my neighbors '00 p/u. As I recall the price for the part was around $15-$20.
