1999 Suburban Steering Problem
Discussion in 'The Garage' started by Dallin, May 5, 2006.
  1. Dallin
    Dallin 1/2 ton status
    Feb 12, 2003
    My 1999 Suburban sometimes looses power steering at low RPMs. If I rev it up just a little it kicks back and seems to work fine. The pump was replaced, but that didn't fix it. I disconnected the wires to the EVO thinking maybe the sensor on the column was bad, but that didn't fix it either. Any other ideas? Maybe a sticky flow control valve? I'm not sure if that would have gotten replaced with the pumpp or not. Thanks in advance.
  2. 1979jimmy350
    1979jimmy350 1/2 ton status
    Mar 24, 2004
    Ann Arbor Mi
    i have the same problem with my 93 s-10(same steering setup) it only started with the new pump after a while, i belive it is the pump so i am going to replace it this summer
