1999 suburban ticking
Discussion in 'The Garage' started by boscosfire, Feb 19, 2007.
  1. boscosfire
    boscosfire Newbie
    Feb 19, 2007
    wichita
    I have a 99 suburban and there is a ticking noise coming from the oil pan area. towards the back of the motor, I know quit abit about cars and I know that it is not a rod or a main. The ticking noise gets louder when the car is in gear and under load. i do not think it is the tranny. Any help would be appreciated.
  2. Russell
    Russell LB7 Tahoe Status Premium Member GMOTM Winner
    Jun 23, 2000
    7,925
    337
    Fort McMurray, Alberta
    exhaust leak, or rocker stud pulling out of the head?
  3. Chaddy
    Chaddy 1/2 ton status GMOTM Winner
    May 23, 2005
    4,110
    Salt Lake City,Utah
    My guess would be exhaust.
  4. sledheadak
    sledheadak 1/2 ton status GMOTM Winner
    Apr 29, 2005
    1,283
    anchorage,alaska
    possible cracked flexplate
  5. K5er4Life
    K5er4Life 1/2 ton status
    Oct 16, 2002
    1,456
    Bellflower, Ca
    exhaust leak at the manifolds, or possibly cracked flexplate.
  6. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    cracked flexplate or walked out flexplate bolts. Those trucks are known for it(well there is a TSB out about it).\
    either way the trans needs to come out, and you likely need a flexplate.
  7. chevy wrangler
    chevy wrangler 1/2 ton status
    Jun 15, 2006
    3,035
    el paso, texas
    this happened on my uncles 1999 sierra z71 and it was that one of the sparkplug wires was all messed up and he custom made some msd ones and the ticking stopped
  8. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    you'd have a misfire and be able to notice the ARC from the plug wire. Not to say its a terrible thought, it is a possibility. But there is a TSB out about flexplate bolts walking out on those engines and causing a "ticking noise from the bellhousing area".
  9. stallion85
    stallion85 1/2 ton status
    Jul 11, 2003
    3,659
    Cedar City, UT
    I had the same thing and it turned out to be an exhaust leak. Try that first since it would be the easiest to fix.
  10. supersize75k5
    supersize75k5 OrganDonorRacing.com
    Feb 3, 2004
    8,832
    4
    gilbert az
    exhaust all the way;)
  11. Leper
    Leper 1/2 ton status
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    I agree with the flexplate or exhaust.
  12. daleearnhardt01
    daleearnhardt01 1/2 ton status
    Aug 29, 2002
    3,223
    Richmond, VA
    Probably exhaust, mine is leaking at the collector on one side as well..
    I have heard of rod bearings being somewhat of a problem on the vortec rigs but I wouldnt worry too much, my 98 has 68k miles and it has a cold knock every now and then..
  13. boscosfire
    boscosfire Newbie
    Feb 19, 2007
    wichita
    how do I find out about the tsb. could sombody send me a link
  14. bigbluesuburban
    bigbluesuburban 1/2 ton status
    Feb 8, 2006
    1,362
    Constant State of Perpetual Anger
    Well what did you find out? What was the verdict? Don't leave us hangin on this stuff. Remember we have needs.
    Flexplate?
    Exhaust Leak?
    Rocker Stud?
  15. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    Loose convertor bolts, or a cracked flexplate.
