1o bolt vs. Dana 44.
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Truckdweld, Apr 9, 2001.
  1. Truckdweld
    Truckdweld Registered Member
    Jan 26, 2001
    26
    Sonoma county, CA
    The topic says it all. I am wondering if i should swap out my 10 bolt front for a dana 44. Does anyone have an opinion on which one is really better.
  2. SlyDog
    SlyDog 1/2 ton status
    Oct 23, 2000
    3,035
    Scottsdale, Arizona
    Dont switch if your expecting a strengh increase cause ya wont get it.
    - SlyDog [​IMG]
  3. CaptCrunch
    CaptCrunch 1/2 ton status
    Feb 2, 2001
    3,596
    Minnesota
    Overall IMO the dana may have a tiny bit more strength since it has more splines unless you get one of the 30 spline 10B's. Other factor is if the axle shafts in the D44 have the smaller u-jt's... that's not good. Not worth dealing with unless you are changing gears... if you want strength get aftermarket axles of a FF kit for it ... or a Dana 60 [​IMG]
    1987 Chevy K5 Blazer- 350 TBI
  4. thatK30guy
    Jan 12, 2001
    32,076
    55
    Both are pretty much equal in many areas. One has some weaknesses and the other the same. I will look for an article in a magazine that you can refer to.
  5. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    imo it is not worth the hasle the 44 is not much stronger than the 10bolt if you would like more streangth go to a dana60 14ff combo
    77blazer see it at<A target="_blank" HREF=http://community.webshots.com/user/ssmith6333>http://community.webshots.com/user/ssmith6333</A>[​IMG]
