1st gen 465 hydro swap
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by 55Willy, Dec 22, 2005.
  1. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    my 68 had a 3 on the tree.. but the PO put a 465 in it, now it's my turn, I'm going hydrp with it. how do I go about hanging pedal and where to poke holes....
    also can I keep the stock pedals??
  2. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
  3. Yukon Jack
    Yukon Jack 1/2 ton status
    Jul 25, 2002
    1,984
    Rose Hill, KS
  4. megahillbilly
    megahillbilly Registered Member
    Apr 29, 2005
    22
    magalia, ca
    I'm workin on mine right know i'm use'in all jeep cj stuff from 80-81 iron duke. if you look in the a/a nv4500 manuel they have a pic of the slave the master is the same model and era finding the spot to mount the was easir than peckin at ths key board
  5. 55Willy
    Jun 2, 2001
    9,946
    Keizer, Or
    hey yukon you wouldn't happen to have that firewall pattern would ya??? that would help me out a ton.
  6. Yukon Jack
    Jul 25, 2002
    1,984
    Rose Hill, KS
    Yep, I sure do. I will locate it this weekend. PM me your address and I will mail it to you.
  7. gmcman7202
    gmcman7202 1/2 ton status
    Sep 19, 2005
    181
    The land of FIBS
    can someone tell me what the master and slave stroke and bore size is that should be used? what 2 units are best suited for this application? i am going to also convert to hydro because i am having linkage problems, thus not being able to release the clutch all the way, therefore i cant shift....
  8. Yukon Jack
    Jul 25, 2002
    1,984
    Rose Hill, KS
    The pattern is in the mail to you this morning.
