1st GEN. Blazer TOP........HELP!!!!!
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by ED70K5, Sep 7, 2000.
  1. ED70K5
    ED70K5 1/2 ton status
    Apr 28, 2000
    179
    Texas, USA
    I just bought a used hard top for my 1970 K5, but the guy didn't know from what year it came from. I know its for a 69-72 full top K5, but is it single or double wall?? I know that there is differant mounting involved with the two differant version of tops! How can I tell?? Will it bolt on to my 70 K5?? Where do I go from here??? The top came with no mounting hardware, so I have to find it myself. I want to be able to put the top ASAP, when I pick it up in a week!
    Blazin' in TEXAS!
  2. Blazer1970
    Blazer1970 1/2 ton status
    1,600
    Old Mission, MI
    Single wall tops bolt down from the top, which means that if your truck was originally so equipped, it will have the nuts tack welded under the bed rails. The double walls bolt up from the bottom, which means clearance holes in the bed rails. I think the holes are in the same place on both tops, but not certain. Worst case is you have to drill new holes, best case is it bolts right on. There are also two brackets that hold the back of the top down, hope you have them, or that they come with the top.
    Tim
    1970 Blazer CST 4X4 350 SM465 NP205
    1987 Suburban 4X4 350
    1988 Chevy Pickup 4X4 350
  3. ED70K5
    Apr 28, 2000
    179
    Texas, USA
    Upon inspection I found something really weird! On the driver side bed rails there is oval holes with nuts tack welded under the rails, but on the passenger rails there is round holes with no nuts underneath! What gives?? Also the holes don't seem to line up with each other from bed to bed rail! I'm confused............maybe I should just buy a SOFT TOP!! One more question...........how many bolts are used on each bed rail to mount the top??
    Blazin' in TEXAS!
  4. blazer72
    blazer72 1/2 ton status
    Apr 13, 2000
    939
    KCMO
    6 down each side 2 to the windshield frame, 2 though the sunviser mounts. 2 to the inside top of the talegate openning, if I count right thats what 18 or so [​IMG]
    I understand the jeep thing I drive a BLAZER!!
    Ken
  5. ED70K5
    Apr 28, 2000
    179
    Texas, USA
    what are these two brackets mentioned in the second post?? I don't think I have them. Can they be fabricated or are they sold by anyone??
    Blazin' in TEXAS!
  6. Blazer1970
    1,600
    Old Mission, MI
    Sounds like someone swapped a bedside on your truck, so now you have one of each. I have never seen the brackets for sale, they are pretty simple, and could be fabricated.
    Tim
