1st gen clutch linkage
Discussion in 'Parts & Trucks Wanted' started by TED, Apr 14, 2003.
  1. TED
    TED Registered Member
    Nov 27, 2002
    81
    San Jose, CA
    I need the part that mounts between the frame and block, I think it might be called a z-bar? I have everything else.
  2. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    v8 or 6 cyl ?
    6 cyl ones longer than v8 ones, 6 cyl uses longer ball block mounted bracket
    measure from block mounted ball bracket over to the little bracket on top side of frame rail, i have a few around two different lengths
    dont measure from end of ball, measure from base of it directly on face of the flat bracket.
    i used ot have tons of these, but scrapped alot of them last fall and some before that, but still should have one or two of both left in attic
    thanks
