1st gen diesel conversion
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by CustomCruiser, Dec 2, 2002.
  1. CustomCruiser
    CustomCruiser Registered Member
    Jan 10, 2002
    12
    Texas
    No luck with archive search. Has anyone swapped a 6.2/6.5 diesel into a 1st gen K5? Seems there may be a firewall clearance problem. Current 350 is not origional. I like the idea of 20+ mpg for my convertible K5 but don't want to cut the roof off the '84 diesel. Thanks.
  2. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    I don't have any real info for you but if I was going to swap a diesel into my truck I wouldn't use a chevy deisel. The dodge and ford motors were designed by guys that know about diesels!
  3. BARRAZA
    BARRAZA 1/2 ton status
    Oct 17, 2001
    259
    USA
    Seeing as how this guy already has two 6.2 powered vehicles, I doubt he is looking to swap a cummings or navistar. Also, the 6.2 was designed by detroit diesel, and they "know about diesels". Yeah, you're never going to get 500+ ft lbs from a 6.2, but they are good alternatives to a small block for towing and can get great gas mileage. As for putting one in a first gen, I have seen one and the guy who had it never mentioned firewall clearance problems. A 6.2 has the same mounting points as a small or big block and generally fits in the same space. Some first gens came with bigblocks so I doubt you'll have any problem.
  4. CustomCruiser
    Jan 10, 2002
    12
    Texas
    Thanks. I've had three 6.2's and continue to be impressed with this light duty diesel. As my 1st gen never tows a gooseneck, this engine may make an ideal daily driver.
