1st gen frame to 85 body
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by FastFob, May 29, 2002.
  1. FastFob
    FastFob Registered Member
    May 25, 2002
    25
    East Bay San Francisco
    I have access to a 85 blazer that is in great condition but I
    hate dealing with Smog. Originally I wanted to get a pre-1974
    Blazer, but those are few and far between.
    Any of you know if the frame of the 1st gens and 2nd Gens are interchangable? I want to buy a rustbucket 1st gen and drop the 85 body on it, So technically the Blazer would be
    Smog exempt and I would be a happy camper.
    Any past experiences or tips?
  2. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    Hate to burst your bubble but I think(ouch) that the DMV goes off the body for the year not the frame. So if yo were to do the oposite you can doge the smog devils!
  3. FastFob
    May 25, 2002
    25
    (I just got back fromthe DMV)
    Actually they go off the Frame/Engine Combo, but since
    it would be a pre-1974 it would be Exempt and all they would go off would be the Frame.
    Actually, some 4X4 magaziine is doing the same to a Suburban they are doing PreRunner style.
    They have a 73 frame and totally backhalved it and tube-framed it. Then they are going to top it off with a Current style suburban body. Complete with Big-Block.
  4. Burt4x4
    6,854
    WOW, great stuff! I guess that is what I get for ASSuMEing I know how DMV thinks!!/forums/images/icons/laugh.gifLOL
    Thanks for the update/correction!
    Good Luck Too!
  5. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    The frames are not the same. You will have to find a 73....
    The front springs are shorter, the wheelbase is shorer, and I'm sure none of the body mounts will line up.
  6. bouncytruck
    bouncytruck 1/2 ton status
    Oct 11, 2001
    858
    Bothell, WA
    Aren't the second gen frames either narrower or wider than first gen too?
  7. Greg72
    Mar 5, 2001
    15,681
    1,392
    642 Days to BB2018
    Bouncy,
    I can tell you this......they are either narrower, or wider, or exactly the same! /forums/images/icons/laugh.gif
    Man, I'm feeling punchy today....must be the nice weather. /forums/images/icons/smile.gif
  8. stylin6
    stylin6 Registered Member
    Apr 1, 2002
    40
    Kansas
    I've got a 70 Suburban mounted to a 77 Suburban frame. The first generation frame was wider than the second generations- which means you'll have to fabricate all your mounts. The wheelbase is also different (my rear axle had to be moved forward about 3 inches). Understand your talking about a blazer, not a suburban but I'm sure there are a lot of similiarities as far as the frame.
  9. 2quicK5
    2quicK5 Registered Member
    Apr 18, 2001
    46
    TN
    I'd go with the 73 Blazer frame. Everything will bolt up just fine and 73s are known for rusting out badly, so you should be able to find one with very little body left cheap.
  10. bouncytruck
    Oct 11, 2001
    858
    Bothell, WA
    Greg, LOL! I guess I deserve that! /forums/images/icons/laugh.gif
