1st GEN K5 Speedo Problems
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by ED70K5, Sep 11, 2000.
  1. ED70K5
    ED70K5 1/2 ton status
    Apr 28, 2000
    179
    Texas, USA
    My speedometer is not working. Where should I start looking?? Do I have to yank out the whole cluster?
    Blazin' in TEXAS!
  2. blazer72
    blazer72 1/2 ton status
    Apr 13, 2000
    939
    KCMO
    No start at the other end undo the speedo cabel from the t-case and spin it with a power drill, haveing some one look at the speedo to see if it working. If it does and its a 50 50 chance it will work then its the speedo drive gear on the out put of the t-case. I fi t does not work then pull the cluster to see if the cabel is ok.
    I understand the jeep thing I drive a BLAZER!!
    Ken
  3. ED70K5
    Apr 28, 2000
    179
    Texas, USA
    The cable is screwed into the back of the speedo! How do I get the cable of the t-case?? I have to go buy a wire brush and get 30 years of grime of the t-case/speedo cable connection first!!
    Blazin' in TEXAS!
  4. blazer72
    Apr 13, 2000
    939
    KCMO
    the cabels is atached to the t-case in the same way as the speedo head
    Ken
