1st Gen Lift Measurement?
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by Triaged, Aug 9, 2001.
  1. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    I was looking through the group pics from Hollister and realized that my truck looked the lowest of all the 1st gen’s (except for Steve Chin’s) even with 36” tires.
    <a target="_blank" href=http://community.webshots.com/scripts/editPhotos.fcgi?action=showMyPhoto&amp;albumID=18605888&amp;photoID=18664388&amp;security=GdCpjzeyPC>1st Gen Hollister Pic</a>
    I thought I would start a post like the ’73- guys did on lift height. I think I have a 4” lift. I have 4 leaves in the front and 5 leaves + overload in the rear with 4” blocks.
    These are some of the measurements I took (all measurements I took are from bottom of the flat part on the bump stop bracket to the axle tube):
    Front passenger side......12 1/4”
    Front driver side.............12 3/8”
    Rear passenger side.......11 1/2”
    Rear driver side..............11 5/8”
    So come on. Go out and measure your trucks, post your measurements, and what lift you think you have. It would be great to have a few stockers post so we have something to base on.
    '71 Blazer CST w/ a 400sbc, 4" lift, 36" Supper Swampers, and alot of rust
  2. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    Cool! I will get the measurments tonight!
    I have 4" Rancho front springs w/4leafs, rear is 5 1/2" Superlift spings w/7leafs. Oh and the front has ORD's front shakels.
    <a target="_blank" href=http://www.geocities.com/baja/5099>www.geocities.com/baja/5099</a>
  3. Blazer1970
    Blazer1970 1/2 ton status
    1,600
    Old Mission, MI
    Mine is stock, I will try to remember to measure it for comparison. You should also note whether you have the hard top on or not.
    Tim
    70 Blazer CST 4X4 350 SM465 NP205
    87 Burb 4X4 350
    01 GMC 2500HD 4X4 Duramax/Allison
  4. Steve_Chin
    Steve_Chin 1/2 ton status
    Mar 6, 2001
    1,126
    Foster City, CA, USA
    Mine's stock wit hteh HD front springs and sagged-out rear springs (and 2" blocks to make up for that). I will endeavor to get the measurements tonight.
    I checked and the front is 8.4375" from the bottom of the bump stop mount to the top of the front axle on both sides. The rear is 9.5" from the bottom of the frame rail to the top of the rear axle on both sides. This is with the top on and the truck in the condition as described above.<P ID="edit"><FONT class="small">Edited by Steve_Chin on 08/12/01 05:03 PM.</FONT></P>
  5. EricM
    EricM Registered Member
    Apr 14, 2001
    61
    Savage, MN
    I have 4" skyjacker spring in front and 6" skyjackers in the rear. These are on a 14 bolt and Dana 60 not sure if that matters. With a softtop.
    Front 13.25"
    Rear 12"
    Eric M.
  6. Triaged
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    I forgot to mention that. The hard top is off. The back seat was also out with my 35" spare sitting between the wheel wells.
  7. harry
    harry 1/2 ton status
    Feb 9, 2001
    106
    san diego, CA
    15 1/2" up front (D60), 13 1/4" in the rear (14FF). stripped to the bone (only frame and body).
    harry
    69k5
  8. 1 FN HI K5
    1 FN HI K5 1/2 ton status
    Aug 7, 2001
    465
    Northern CA Out in the stick\'s
    On my 72 front is 20 1/2 rear is 21 with the top off. with 44 super swampers. 15 inch lift with 3 inch body 18 inches of total lift.
    1 FN HI K5
  9. 71RestoRod
    71RestoRod 1/2 ton status
    Mar 7, 2001
    178
    Evergreen, CO
    Looks like about 6" to the concrete in the rear and 8" to the concrete in the front. Springs, axles, wheels and tires should improve these measurements considerably! Keep those numbers coming!!!
  10. Triaged
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    LOL!
    What lift are you planning on if any?
  11. Greg72
    Mar 5, 2001
    15,680
    1,391
    642 Days to BB2018
    My 1972 Stats:
    Front - 12.25"
    Rear - 11.50"
    Caveats: Measurement in the front is from the axle tube itself to the metal bracket that holds the bump stop... not from the flat mounting plate that the front leaves rest on. Also in the rear, the bumpstop is a funny (non-flat) shape, so I tried to measure as close to where the rubber and plate actually meet.
    Top is removed
    No Rear Seat
    "Greg72" Custom Subwoofer enclosures (probably 20 lbs ea)
    1/2 Tank of Fuel
    No Bumpers
    35" Tires....(which measure about 33")
    4" Rough Country Lift (Springs front, Blocks rear)
    -Greg72
  12. 71RestoRod
    Mar 7, 2001
    178
    Evergreen, CO
    Triaged,
    Originally, I thought I wanted a tame 2" front and 4" rear lift to keep a relatively low CG. I'm aiming for a comfortable street and somewhat capable off-road compromise. I drive on mostly crooked roads that are often icy. Lets just say that if I take it to Moab it will only be to tow the (non-existent) rock crawler...but after seeing the Hollister pics, I'm all confused!
  13. Triaged
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    I like the idea of a low CG. My truck had the 4" lift on it when I bought it. I really like the short lift with big tires look (am almost thinking about 2" lift w/ 38's).
  14. Esteban86K5
    Esteban86K5 1/2 ton status
    3,712
    Bakersfield, CA
    <font color=blue>I</font color=blue> think you should go with an 8 inch lift and 44's. Forget the low CG. You don't even wheel the dang thing. It sits all pretty in the driveway. And by the way do you know Chata?[​IMG][​IMG][​IMG][​IMG][​IMG][​IMG]
    You knew I was gonna give you a hard time about this didn't ya?
    <font color=blue>Esteban</font color=blue>
    <font color=red>HAVE YOU EVER HEARD OF CHATA?
  15. Esteban86K5
    3,712
    Bakersfield, CA
    So Dan, what lift do you have? Did any of these guys measurements help you figure it out?
    <font color=red>HAVE YOU EVER HEARD OF CHATA?</font color=red>
    <a target="_blank" href=http://coloradok5.com/gallery/Estebans-album>http://coloradok5.com/gallery/Estebans-album</a>
  16. Triaged
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    Nobody with a stock Blazer has posted yet (come on guys post away) so I have nothing to compair to. It does look like mine is shorter than some of the others w/ 4" lift. Maby it has sagged an inch?
  17. Triaged
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    Just bringing this back to the top.
    Come on some of you stock guys have to have a tape measure :o)
    <a target="_blank" href=http://community.webshots.com/user/triaged>See it Here </a>
  18. Roostr84
    Roostr84 1/2 ton status
    Aug 19, 2000
    451
    NJ
    My stock lift 69 has 2 leaves up front and 5 in the back. I wouldn't go by the measurements though b/c I am sure they have settled in the 33 years it has been around.
    Chris =)
    I think the exhaust fumes have finally gotten to me!!
  19. Triaged
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    To the top for all the new people.
  20. ZZ4x4
    ZZ4x4 1/2 ton status
    Oct 17, 2001
    542
    Garland, TX
    I'm showing 14.0 in front and 11.75 inches in the rear.
    4 inch tuff country springs , ORD shackle flip in rear, 14FF, plus 2 inch body lift. JT
