1st gen Tranny question
Discussion in 'The Garage' started by Stroked72Blazer, Oct 18, 2003.
  1. Stroked72Blazer
    Stroked72Blazer 1/2 ton status
    Nov 9, 2002
    352
    Little Rock, AR
    I have a (Senser?) type plug just above where the dipstick goes in. It has two male spaid plugs on it. What the heck is it? Or has someone just swapped in a later model tranny with a lockup converter or something like that?
  2. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    I believe that is part of a smog device that was used early on and it works in conjuction with an electric/vacuum solenoid and vacuum lines to the distributor.
  3. Blazer1970
    Blazer1970 1/2 ton status
    1,600
    Old Mission, MI
    4X4HIGH is correct, it is a high gear indicator switch for the TCS (transmission controlled spark) system. It indicates that the tranny is in 3rd gear. I seldom see a truck that still has the TCS system intact, so you can likely just ignore it.
  4. Stroked72Blazer
    Nov 9, 2002
    352
    Little Rock, AR
    Cool Thanks. Does anyone know the thread size so I can just put a plug in it? Is it pipe thread or regular?
  5. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    I haven't seen one in a long time but I believe it is 1/8" pipe.
