1st Gen Tube Doors
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by vtblazer, May 1, 2007.
  1. vtblazer
    vtblazer 1/2 ton status GMOTM Winner
    Sep 30, 2003
    2,471
    Central VT
    Finally got around to building some. :woot:
    Very simple but effective.
    Worked the original bumper plate into the design so the tube doors will help support and maintain the correct door opening like the factory doors do.
    Used factory hinge plates and a factory door latch, works sweet.
    Closes/opens just like the full doors.
    Thought about another tube running parallel with the top of the bed side but once I mocked it up and sat in the seat, I decided it would get in the way.
    It was high enough so that it took away from the reason for having tube doors in the first place IMO, to be able to lean out and see that front tire. :smirk:
    These doors tie into one of my most recent mods...quick release hinges.
    I can swap out doors in under 3 minutes now. :D
  2. bouncytruck
    bouncytruck 1/2 ton status
    Oct 11, 2001
    858
    Bothell, WA
    Looks great. Simple is usually the best solution.
    What are you running for innner fenders up front with the cut out openings?
  3. 2wdBlazer
    2wdBlazer 1/2 ton status
    Feb 11, 2007
    118
    Tampa, FL
    Awsome man. They turned out pretty cool. I had something like this in my mind with a removable cover. There is a post in the vendor section about making some of these. So what's the cost on these? ha ha
  4. GotLabs
    GotLabs 1/2 ton status GMOTM Winner
    Jul 30, 2005
    2,795
    Transient, USA
    Looks good!
  5. Yukon Jack
    Yukon Jack 1/2 ton status
    Jul 25, 2002
    1,984
    Rose Hill, KS
    Very nice! :bow: :bow:
  6. suspectdon
    suspectdon 1/2 ton status
    Jun 13, 2005
    111
    Menomonie WI
    They look great!
  7. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    Very Nice VT:D
  8. vtblazer
    Sep 30, 2003
    2,471
    Central VT
    Now it's on to door #2. :whistle:
    Spent all day yesterday doing the rock rings but it's back to the door today.
    If I spend as much time wheeling it this year as I have wrenching on it, I'll be way happy. :smirk:
  9. vtblazer
    Sep 30, 2003
    2,471
    Central VT
    Well...absolutely nuttin' :smirk:
    I'm doing a hoop for the front shocks soon cause they need to be relocated from their current position (tire rubs on em) so I may incorporate some kind of inner fender at that time.
    Those fenders have been cut 4.5"s all around from stock, so there's no reason to even consider using the original ones.
