1ton axle swap ques/help
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by TXsizeK5, Jul 10, 2002.
  1. TXsizeK5
    TXsizeK5 1/2 ton status
    Aug 26, 2001
    2,518
    College Station, TX
    If i went to an 14 Bff rear and/or an eaton one ton rear end. What all do I have to modify on there or will it bolt right up? Do i need bigger sized rims beucase of bigger brakes or can i just get 8lug 15" rims? Also, do they make a 6 lug conversion?
    Ohh 1 more question, doe sit hurt anyhting to run wider and more aggresive tires in the back... ie. 35x15.50 SX in the rear and 35x12.50 BFG in the front? Thanks
  2. reddog64
    reddog64 1/2 ton status
    Nov 9, 2000
    3,325
    Federal Way, Washington
    Re: Swapping rear axle
    should bolt right in
    and tire size (width) wont matter just run the same diamiter
  3. TXsizeK5
    Aug 26, 2001
    2,518
    College Station, TX
    So that means i can use same springs, same ubolts, same driveshaft? And what about the rims, do i need to get bigger ones becuase of the brakes on teh 14b? Or do they even make 8lug 15" rims? thanks
  4. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    This has been covered to death, do a search for detailed answers to every one of your questions.
    Short story.
    3/4 to C14 FF will bolt in with possible exception of e-brakes and shocks depending on the source.
    8 lug 15" steel wheels will fit, even on the 1 ton.
    6 lug conversion is possible only with machine work. See Dorian Yeager.
    Avoid the Eaton, you don't want it.
    Driveshaft will need modification OR you can get a hybrid u-joint to adapt. Do a search for the u-joint part number if you want it, I don't recall...
  5. k30gambi
    k30gambi 1/2 ton status
    Dec 24, 2001
    108
    illinois
    I'll add some gas, no, jet fuel to the fire. I think 1/2 tons have the rear shocks on the outside of the frame, my 1-ton has them mounted on the inside. I am 99% sure the spring pads are a different width apart, maybe some other ton luvers will know. So I think you will have to relocate the spring pads and shock mounts if you go with a ton axle but I think you will only have to relocate the spring pads if you go with 3/4ton rear end. /forums/images/icons/confused.gif
  6. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    The 3/4 ton, you don't have to change the pads/shock mounts just on the 1 ton.....
  7. TXsizeK5
    Aug 26, 2001
    2,518
    College Station, TX
    So shock and spring perch relocations... whats wrong with the eaton rear end?
  8. BlazerGuy
    Apr 20, 2000
    9,206
    abcde
    I don't know much about the Eaton rears but I guess it'd be hard as hell to find parts for them, seeing as how they stopped making them in '72.....or was it earlier.....hmmm...
  9. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    BlazerGuy has it right, no parts.
