1Ton caliper installation
Discussion in 'The Garage' started by Zeitler, Sep 19, 2006.
  1. Zeitler
    Zeitler Registered Member
    Feb 22, 2005
    99
    Sweden (Northen Europe)
  2. hack500
    hack500 1/2 ton status
    Sep 16, 2005
    523
    Templeton, Ma
    silver spring on the bottom, black spring on top, and key in the middle. put the silver spring on the caliper bracket first (tabs down over the edges) then put the black spring on top of the key and tap them in with a small hammer.
  3. sweetk30
    Nov 1, 2004
    25,526
    526
    horseheads , ny 14845
    i dont see how he is going to fit both springs in there. there is 2 diffrent styles there. use the black one on top of the bar/wedge. then before all of that clip that shinny little one on the bottom of the inner pad so the little tab sticks in to the rotor so it squeals when the pads get low.
    that looks like a universal kit. possible other bendix brake aplications used the silver one.
    slide caliper on rotor and lift up to top grove. then slide the block/wedge and black spring in on bottom. then tap in till full goverage. and align bolt hole and install lock bolt.
  4. hack500
    Sep 16, 2005
    523
    Templeton, Ma
    :doah: sweetk30, you're right.
    just went out and looked at mine and there was only 1 spring in there. damn... must be getting senile in my old age.
  5. Zeitler
    Feb 22, 2005
    99
    i don't get this .. the inner pad sits very loose , it would probably make some noise..did i put the little shiny spring on wrong???
  6. Joe Matsko
    Joe Matsko Newbie
    Sep 21, 2006
    NE Ohio
    Hey Z- Mine uses the silver spring (ears facing down) on top of the "supportKey". SweetK30 descirbes the little shiney spring install very well. Mine is a bit loose as installed but makes no detectable noise. Then again I can't hear much over the sound of those TSL's!
