1Ton folks with 38" or bigger tires
Discussion in 'The Garage' started by Depdog, Jan 10, 2003.
  1. Depdog
    Depdog 1/2 ton status Author
    1,657
    Georgia
    1Ton folks with 38\" or bigger tires
    What pressure are you running yours at. Especially if you have the Bias TSL's I have 39.5's and run them at 26 psi, seems too stiff.
    Depdog
  2. CK5
    May 19, 1999
    21,623
    701
    CO
    Re: 1Ton folks with 38\" or bigger tires
    Usally at around 24 PSI on the street.
  3. yellowK20
    yellowK20 Well Lubricated Premium Member GMOTM Winner
    Dec 26, 2002
    7,602
    551
    Wasilla AK,
    I have the same tires on my k20 (bald) I run 19-psi cold in mine with my 12 inch lift with my 6 inch superride I ran 26-psi cold I also have 15 inch rims /forums/images/graemlins/truck.gif
  4. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    i run 38x13x16in bias tsl swamper's and run 22-24psi on the street and 10psi on the trail and 8-10psi on the sand hope this helps /forums/images/graemlins/smile.gif oh and i have a very even tire wear pattern /forums/images/graemlins/smile.gif
  5. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    39.5x15x16.5 TSL's and they are run on the street at 17 psi
  6. Greg72
    Mar 5, 2001
    15,681
    1,392
    642 Days to BB2018
    Depdog,
    If you check the sidewall of the tires, you will see a MAX PRESSURE and a MAX LOAD.... Those are the keys to setting the pressure.
    As an example: My truck rides on 38.5 TSLs (Bias Ply) which are rated at 30 psi at 2400 Lbs. I know that my truck weighs just under 5000 lbs with almost perfect 50/50 weight distribution, so each tire is actually "seeing" approximately 1250 Lbs of weight. Theoretically, that means I should be able to run around 15 psi on the street without overloading the tire.
    This seems to be valid, as I run the tires around 17 psi and notice that the outer 1/2" of tread on both sides of the tire is not being "scuffed" on the pavement when I drive....letting the air down to 15 psi would ensure full tire contact, at the expense of even WORSE fuel mileage.
    You might have missed an article in one of the recent mags about this subject, but it did a pretty good job of covering how to calculate a "valid" tire pressure based on load, etc.
    One other thing, I have a suspicion that MOST people running big tires like TSLs, tend to overinflate them (like a radial)....since most of the ones I've seen that are "bald" are only bald in about the middle 4 inches!!!! Kind of a give-away if you ask me!!! /forums/images/graemlins/smile.gif
  7. desertrat67
    desertrat67 Hawk Driver
    Jul 5, 2001
    3,982
    74
    Dumfries, VA
    38's on a crewcab wiht 20-25 depending on if i want a firmer right or not.
  8. willyswanter
    willyswanter 1/2 ton status GMOTM Winner
    Dec 24, 2000
    2,690
    Bakersfield, CA
    I have 39.50 TSL's, but the special E load rated version and I run 50 PSI /forums/images/graemlins/shocked.gif
  9. SAVAGE1
    SAVAGE1 1/2 ton status
    May 22, 2000
    1,104
    BAY AREA, CA
    42's on 20psi /forums/images/graemlins/thumb.gif
  10. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    Depends on the temperature. If its real cold, I find that the tire will ride better at a higher pressure. Normally I run about 22 to 24 pounds on the street and about 10 for the trail. I have gone down to 4 before for deep snow but the tires like to burp.
  11. 72THING
    72THING 1/2 ton status
    Nov 26, 2001
    501
    Ranburne, AL
    Glenn, I have the same tires and I'm running 18 psi front and 16 psi rear cold. Seems to work pretty good. Anything higher makes the tire look too bulged out in the middle,
    Will
  12. BOWTIE
    BOWTIE 1/2 ton status
    Dec 28, 2000
    2,018
    Outside with the sawzall.
    39.5 boggers. 20 psi on the street. 5 psi wheeling.
  13. Sandman
    Apr 15, 2002
    5,653
    Pocatello, ID
    How does the 5 psi work on the boggers? I've got a set now of 39.5"'s on a 10" wide rim and on the tsl's I ran before, below 8 pounds it got iffy. Do the boggers hold the bead better? I've got a deep snow run at the end of the month and would like to run as low as I can.
  14. Storm Trooper
    Nov 24, 2000
    4,640
    38.5x15.5x16.5 TSL's
    18-20 on the street
    8-10 on the trail.
    I tried about 4-5 but I pulled the inside bead off of my beadlocks. /forums/images/graemlins/frown.gif
  15. BOWTIE
    Dec 28, 2000
    2,018
    i must be lucky. with my beadlocks i haven't had any problems with the inside bead popping off. or at least not yet. /forums/images/graemlins/crazy.gif
    steering just gets a little slopy.
    ric
  16. Sandman
    Apr 15, 2002
    5,653
    Pocatello, ID
    Ahhh. You have beadlocks. Someday. /forums/images/graemlins/grin.gif
  17. UNCLE CRACKER
    UNCLE CRACKER 1/2 ton status
    Dec 29, 2001
    937
    PORTLAND OR
    39.5 swampers front , boggers rear. I run 18-20 psi on the street. on the trail 5-7 psi. in the sand 1-5 psi. I havent had a problem with blowing the inner bead either. I run the Allied 32 bolt beadlocks.
  18. Sandman
    Apr 15, 2002
    5,653
    Pocatello, ID
    I had one bogger down to 3 pounds by accident once and it stayed on! I might try 6-7 pounds this next week in the snow and see what happens.
  19. Storm Trooper
    Nov 24, 2000
    4,640
    The real trick to pulling the inside bead off is to have your pressure down, then back up a 45-50 deg. hill to let other wheelers by, then pull back on the trail while trying to turn. Oh, and don't forget to be at 10,000+ ft. elev. on a cold day. That might help /forums/images/graemlins/grin.gif
  20. Sandman
    Apr 15, 2002
    5,653
    Pocatello, ID
    I personally like flying around a snowy corner with the gas floored. that ripped off all four tires once. /forums/images/graemlins/grin.gif
