1ton vs 3/4 ton 14 bolt
Discussion in 'The Garage' started by steedalx, Jan 21, 2004.
  1. steedalx
    steedalx 1/2 ton status
    Dec 19, 2003
    142
    Chattanooga, TN
    Is the only difference between a 3/4 ton and 1 ton 14 bolt rear the size of the drums?
  2. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    Spring perch location. One tons have the perches two inches narrower total (each perch needs to be moved one inch outwards to make it work in a 3/4 ton or vice-versa).
  3. Bullet
    Bullet 1/2 ton status
    Mar 14, 2001
    1,222
    Abilene, Texas
    Difference is in the spring pad location and shock mounts. 3/4 ton is a direct bolt in for a half ton chassis.
  4. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    3/4 ton uses 2.5" wide brakes
    1 ton uses 3.5" wide, quite a bit bigger
    If you're gonna use discs anyway you won't care.
  5. mudjunkie 82
    mudjunkie 82 1 ton status GMOTM Winner
    Dec 27, 2002
    11,449
    Cleveland Ohio
    1 ton has shock mounts on the inside of the frame....
  6. rjfguitar
    Aug 28, 2002
    9,097
    144
    california
    I would take a 3/4 14BFF way before a 1 ton 14. Like mentioned above it is a direct bolt in besides the u-joint. I used a Neapco conversion u-joint because I think it is better quality than Napa joints. The Neapco part # is 2-1153. The only difference would be the brakes like Tim said but I know I wouldn't wan't the huge 3.5" drums over my HD 2.5" drums because they are heavier than the 2.5's and I already have problems with my rear drums locking up faster than my front disks because they are too big for the 1/2 ton proportioning valve. Hands down...find a 3/4 14BFF over a 1 Ton 14 in my book.
