1tons
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by dpearson, Dec 29, 2000.
  1. dpearson
    dpearson Registered Member
    Apr 10, 2000
    95
    El Paso, TX
    Help, I bought a 14bolt and 60 from a 1ton truck and need to move the perches on the 14bolt. My question is how should I setup the angles on the driveshaft from transfer case to axle. Thanks in advance any photos would be great, I'm going to weld the perches on Sunday.
  2. Chris Demartini
    2,406
    Dumont NJ 07628
    <font color=blue>First cut off the old perches and grind the housing smooth. Now, you can either buy perches from a circle track shop or make your own out of box tubing. Next, place them on top of the axle and bolt it under your truck. now center the axle side to side (the distance between the perches and the end of the housing should be equal). Then use an angle guage to raise or lower the pinion until both angles are equal, now spot weld the perches on and check the angles again. If they check out even, finish welding. Weld in small sections and give time in between welds to prevent the axle tube from getting too hot. Thats basicly all there is to it.</font color=blue>
  3. dpearson
    Apr 10, 2000
    95
    El Paso, TX
    Biggray71,
    thanks, I have the old perches and shockmounts removed and am putting the axle under today to line everything up. But i'm still not sure about the angles you refer to. Is that the angles between the transfer case horizontal and the driveshaft and the angle between the pinion and driveshaft?? Like a stretched out Z. Help!
  4. drivelineman
    drivelineman 1/2 ton status
    Aug 23, 2000
    707
    check out my site for your pinion angle- <A target="_blank" HREF=http://highangledriveline.prodigybiz.com>http://highangledriveline.prodigybiz.com</A>
  5. dpearson
    Apr 10, 2000
    95
    El Paso, TX
    Excellent,
    thanks
