2´´ Lift
Discussion in 'The Garage' started by MR.4x4, Aug 12, 2002.
  1. MR.4x4
    MR.4x4 Registered Member
    Jul 17, 2002
    66
    Hi, i want to lift my Blazer 75 only in the rear, what do you recomend me??
    Know i dont want put any Body Lift, je je /forums/images/icons/tongue.gif
    Shackles??
    The Shackles are going to give me more Flex??
    Thanks for your help
  2. muddysub
    Jun 23, 2001
    10,451
    489
    my garage, Henderson, NV
    only 2" in the rear? either 2" blocks or the offroad design 2.5" shackle flip.
  3. MudbogAD
    MudbogAD 1/2 ton status
    Jun 29, 2001
    672
    Las Vegas Nevada, US
    A bodylift will lift the whole thing so it's impossible to do a bodylift only in the rear. Honestly, your best bet would be some 2 or 2 1/2 blocks.
  4. MR.4x4
    Jul 17, 2002
    66
    I Think that the Shackles are Better, /forums/images/icons/smirk.gif But they will give me some Flex??
    Why do you recomend me the Blocks??
  5. muddysub
    Jun 23, 2001
    10,451
    489
    yeah the shackle flip is better but blocks are cheaper. its your preference.
    me, i'd go with the flip, but i'd go 4" instead of 2".
    why do you only wanna lift the rear? /forums/images/icons/confused.gif
  6. MR.4x4
    Jul 17, 2002
    66
    Hi, i only want to Lift the rear because my tires hits the fender in off-road and in the front i have plenty of clearence.
    The Shackles i can do them my self, but i need to do them of 4´´ to give me 2´´ of lift???
    The Shackles will give me some Flex?? If they give me Flex my tires are going to hit again my fender /forums/images/icons/smirk.gif
    Thanks again /forums/images/icons/smile.gif
  7. mplogic
    mplogic 1/2 ton status
    May 7, 2002
    263
    Phoenix, AZ
    hmm... You should have the same amount of flex whether you do a shackle flip or use blocks. In both cases you are using the factory springs. Why do you just want to lift the rear??? Do you already have some lift up front or is your rear end sagging badly? If it is a sagging problem, your best bet is new or re-arched rear springs. A shackle flip or lift blocks will not fix the problem (permanently) and your spring will continue to fatigue.
  8. mplogic
    May 7, 2002
    263
    Phoenix, AZ
    Oh and I agree that 2" blocks are probably your best bet. The shackle flip is expensive and 2" blocks aren't too bad for axlewrap. If you were going 4" I'd say definately go with the shackle-flip.
