2 1/2 Lift
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by johnny reb, May 9, 2000.
  1. johnny reb
    johnny reb 1/2 ton status
    Mar 6, 2000
    326
    Pittsburgh, PA
    I'm thinking of getting a 2 1/2 suspension lift for my 1986 K5. I don't know much about lifts, so I am wondering if I will have to make any other changes if I put this lift on. Will I need to change the driveline, brake lines, etc. Is this something I can do in my garage or should I have it professionally done? Any suggestions on brands? Thanks
  2. jmpd
    jmpd 1/2 ton status
    Mar 12, 2000
    181
    Mesa, AZ
    Try doing a search on lift kits 2"-3"-4". I know this has been covered several times
  3. ColAdo82K5
    ColAdo82K5 1/2 ton status
    Feb 18, 2000
    789
    MO
    Hey,
    I just installed a Rancho 2 1/2 lift on my 82. front springs, rear blocks, rs-5000 shocks. So far, the only thing i had to adjust was the draglink, which is common. I run 33x12.50x15 's on 15x10 wheels. I havn't done any "heavy wheeling" just light stuff and the lift is great, on and off the road. Mail me if ya got more ?'s. ado84@aol.com
    Colonel Ado
  4. Brady
    Brady 1/2 ton status
    May 6, 2000
    628
    Parachute,Co
    I have the Rancho 2.5" lift (front and rear)on my '73 blazer and it is a real good kit.Ihave broke one rear leave before.I use this rig hard on the most difficult trails(21 road,holy cross,battlement mesa,moab,etc. )The front springs have 5 leaves in the pack.Rancho makes a 3" lift that has 9 leaves in front and will run 36" swampers with swaybar connected.I don't run the swaybar.Brady '73 Beautiful Disaster
  5. JOEBLAZER12
    JOEBLAZER12 Registered Member
    20
    Brady,
    I'm thinking about the Rancho 2.5" lift also. Do you run leaves in the rear(how many) or blocks? What size tires do you run now? What shocks? What gear ratio? Any other mods necessary (steering; driveshafts; T-case). Based on the trails you do, sounds like the suspension works good off-road. How is the on-road ride and handeling compared to stock? Sorry for all the questions, but I need the info. Mine is a daily driver and I want it to ride well and be as reliable as possible. Thanks.
    JOE
    '89 Blazer
