2 1\2 Military Axles Rockwells?
Discussion in 'The Garage' started by 2High4U, Sep 14, 2005.
  1. 2High4U
    2High4U 1/2 ton status
    Aug 20, 2005
    542
    Felton Pennsylvania
    any one got pics of these on their ride?
    I was wondering what the pros and cons where to these?
    majorly my question is... is it possible to hook them up to th sm465 manual tranny and np205
    any good suspension ideas?
    sorry i like to dream... sometimes my dreams come true
  2. RootBreaker
    Nov 29, 2001
    5,117
    173
    Williamstown, NJ USA
    well you dont have to dream too much...
    Pros
    leaf sprung axles - so easy swap from a leaf sprung truck
    extremely low gear ratio
    2 can be had for the price of 1 dana 60 front - ($800 a pair usually)
    STRONG
    lockers available - expensive
    disc conversion available - expensive
    Cons
    heavy
    drum brakes - disc is expensive
    full hydro steering - guess you probably could come up with hydro assist and some how hook it up.. for street purpose
    20" rims - yes you can get centers but costly????
    alot of lift to clear the axle
    anyhow.. I was going to go with them... and still might... someday
    my goal was 15" lift, rockwells (dual steer), and 53" michelins...
    some day donkey... some day.... :haha:
    few pics fer ya...
    for pics checkout..
    www.chevyboys.com
    www.misfits4x4.net
  3. RampageFSJ
    RampageFSJ 1/2 ton status
    Aug 18, 2005
    121
    Ulysses KS
    Disk doesn`t cost all that much if you search in the right places for a pinion brake setup.
    You can find companies that make smaller than 20 inch wheels for them.
    You should run at least a 40 inch tire because of the low gearing and clearance under the axles.
    I may think of something else later.
  4. Leper
    Leper 1/2 ton status
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    Click the link in my sig, click on the Gilmer tab, click on the blue buggy picture "bubba". His bugy runs rockwells and pinion brakes and 44s. Pinion brakes are not street legal though. His has 4 wheel hydraulic steering. With his setup, he can idle up DeWoody in Gilmer.
    BTW you can find Rockwells for 100-200 each
  5. thatK30guy
    Jan 12, 2001
    32,076
    55
    Two choices with disc brakes.
    1. Pinion mount brake. Really a "negative" since the disc spins twice as fast as a standard hub mounted disc. Translates to more heat which warps rotors. Running this setup will allow 15" rims to be mounted once the drums have been removed.
    2. Bearing hub mounted disc brakes. Better for street/highway driving duties. Rims will have to be larger but not sure exactly on the minimum size. Better stopping power since there are discs at each corner.
    All varies on rim size and what you plan to do with the rig. If it were me, I'd go with the hub mounted discs and larger rims, like 20's.
  6. mikey_d05
    mikey_d05 1 ton status GMOTM Winner
    Nov 23, 2004
    10,453
    Minnesota
    Pinion brakes aren't safe for a vehicle that routinely sees street use. Period.
  7. k5 krawler 50
    k5 krawler 50 1/2 ton status
    Jan 26, 2004
    1,467
    Gardnerville, NV
    DP_90K5 has a new rig that he put 2.5 rockwells under. So far his set up is pretty clean looking. Do a search under his name, and you will find his threads about it.
  8. jhellwig
    jhellwig 1/2 ton status
    May 7, 2005
    420
    Bonaparte, Ia
    Has anyone ever seen rockwells with air brakes on them?
  9. mikey_d05
    Nov 23, 2004
    10,453
    Minnesota
    There was talk on Pirate of a Rocky with air brakes on it but it turned out to be a different Merritor-Rockwell axle, not the military toploader style that most people are using.
  10. thatK30guy
    Jan 12, 2001
    32,076
    55
    Yep, I agree. Thats why I posted reason number two:
  11. 2High4U
    Aug 20, 2005
    542
    Felton Pennsylvania
    Steering\Suspension Rockwells 2 1\2 TON
    I Still don't have them but still have a few questions before I get into the actual project.
    I need information on steering set-ups and suspension setups or even a set of plans for what works best in a 73 blazer, i just want to make sure that the drivline angles are ok etc.
    it would be for a dd but i want it rockable also :D
    why does everyone buy up D60 when you can get a front and rear set of 2 1\2 ton axles? :confused:
  12. mouse
    mouse 1/2 ton status
    Nov 10, 2003
    1,448
    Great Falls Mt
    I know a guy who has a set for sale (as of Aug). I don't know the price though.
  13. TLCOR
    TLCOR 1/2 ton status
    Aug 16, 2005
    333
    At ya mama's!
    In Norway we have GMC M6s with 2.5T RockWells that comes stock with manual lockers.. :D
