2 1/2 Ton Rockwell Axles???
Discussion in 'The Garage' started by OffRoader93, Aug 25, 2003.
  1. OffRoader93
    OffRoader93 1/2 ton status
    Nov 30, 2002
    262
    How much lift would an 81 K20 need to fit Rockwells under it? Thanks...
  2. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> When I looked into it a few years ago, I determined that you would need a minimum of about 10" lift springs to get the toploading 3rd member to clear the engine and crossmember in the front. You'd also need to lower the bumpstops a bit to avoid smashing the axle into the engine during suspension compression. </font>
  3. BlueBlazer
    BlueBlazer 1/2 ton status
    Feb 15, 2001
    1,940
    I believe Steve Sharp (not a member of this site) runs his with only 4 or 5 inches of lift with very little uptravel due to lowered bumpstops. Someone who has seen his rig in person could elaborate more on this.
  4. BigOrange90Jimmy
    BigOrange90Jimmy 1/2 ton status Premium Member
    May 24, 2002
    2,923
    Wilmington, NC
    I did some figuring when I was planning on it, and figured that if I tucked the entire engine, tranny, tcase up into the body more, I could get away with about a 6" lift with plenty of clearance.
  5. SkulzNBonz
    SkulzNBonz 1/2 ton status
    Feb 20, 2002
    4,522
    OKC, Oklahoma
