2 241 TC ??'s
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by ftn96, May 17, 2001.
  1. ftn96
    ftn96 1/2 ton status
    Sep 26, 2000
    3,238
    Nashville Tn
    2 241 TC ??\'s
    I was topping off the fluid this morning and once the overflow started, I noticed some metal shavings flowing out with the fluid. On the other hand I am having NO problems with it. Is this SOMEWHAT normal? Should I just change the fluid and go till it drops?
    #2 DOES anyone have the part # for that GM Blue grease for the Slip Yoke splines? I've tried marince grease, white lith, sythetic, hi-temp, wheel bearing, yada yada. All these greases have to low a run off/out factor and it doesn't stay in there very long.
    Will work for beer, parts and tools.
    90-350TBI-TCI700-241-33"-10/12 bolt w/4.10's,
    <A target="_blank" HREF=http://www.nashvillek5.freeservers.com>http://www.nashvillek5.freeservers.com</A>
  2. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    Re: 2 241 TC ??\'s
    Try CV axle grease - the stuff you pack into the CV boots on IFS trucks. VERY sticky stuff!
  3. Ryeguy
    Ryeguy 1/2 ton status
    Oct 30, 2000
    Victoria, B.C.
    Re: 2 241 TC ??\'s
    Metal shavings in drained are not normal. That case has a magnet in the bottom that should have caught that...methinks something is wrong...
    --Rob
