2" 3" lift?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by anatomiczero, Sep 29, 2001.
  1. anatomiczero
    anatomiczero 1/2 ton status
    Jun 26, 2001
    418
    Washington
    2\" 3\" lift?
    What's the biggest suspension lift I could do without messing with brake lines or anything else? I just want to swap the leaf springs and not worry about anything.
    soon to have a blazer/jimmy
  2. dragricinMT
    dragricinMT 1/2 ton status
    Jul 21, 2001
    135
    Billings Montana
    Re: 2\" 3\" lift?
    I had a 2-1/2" that was pushing the limits of my hoses over minor obstacles.
    78-K5 4"Lift 35"Tires 400SB TH350 NP205
    73 Vega 350SB TH350
  3. sapper
    sapper 1/2 ton status GMOTM Winner
    Jul 11, 2001
    3,052
    NoVa
    Re: 2\" 3\" lift?
    if you lift the front your going to have to change some sterring stuff, adjust your drag link and long brake lines would be a good idea. the back would be no prob i went around for months with 3" blocks in the back for saggy butt and thats all you will need there
    <a target="_blank" href=http://coloradoK5.com/gallery/Pauls89K5>http://coloradoK5.com/gallery/Pauls89K5</a>
  4. dragricinMT
    Jul 21, 2001
    135
    Billings Montana
    Re: 2\" 3\" lift?
    You can lift it a couple of inches without all the other stuff. Once you get about 4" or more you need raised steering arm swaybar lowering kit or disconnect kit, longer hoses,and possibly longer vent hoses. Also might run into driveshaft problems.
    73 Vega 350SB TH350
  5. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    Re: 2\" 3\" lift?
    I have a 2 1/2 inch lift on my Jimmy. I didn't have to do anything to the steering or brake lines. I did put a sway bar disconnect on about 2 years after the lift. I don't wheel really hard, so the stock brake hoses have lasted, but now that I have the sway bar disconnect I am going to put on longer brake lines just to be safe, and because I was advised to by other people on this site. Better safe than sorry.
  6. anatomiczero
    Jun 26, 2001
    418
    Washington
    Re: 2\" 3\" lift?
    Cool, I'll go with a 2 1/2" lift then eventually put on extended brake lines. It Isn't hard to put on brake lines is it? I'm taking auto shop in school, so I should know how to do that stuff by then.
  7. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    Re: 2\" 3\" lift?
    I got away with running a 2 1/2 lift and offraoding for about 2 years. I did run some high articulation and got away with it. Probably just because I didn't know any better at the time. If you just going to drive it around town and or graded gravel roads the brake lines should be fine, and the steering too. If you plan on offroading anything romotely serious then get the brake lines done.
