2.5 lift
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 6.2L Jimmy, Jan 14, 2002.
  1. 6.2L Jimmy
    6.2L Jimmy 1/2 ton status
    Jan 2, 2002
    164
    Montreal,Quebec
    How much lift do you really get from a 2.5 inch lift?
    1989 GMC Jimmy 6.2L 4x4,1969 Camaro Z/28 502 C.I. B.B.C.
    BLOOD,SWEAT AND GEARS!
  2. mudhog
    Nov 6, 2000
    17,899
    portland oregon
  3. 6.2L Jimmy
    Jan 2, 2002
    164
    Montreal,Quebec
    I heard stories of about 4-inches?
    Wow I feel dumb!
    Thanks.? :)
  4. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    If you plan to offroad your truck you might be better off with 4". I wish I had a 4" instead of the 2.5" that I have. It would have saved me alot of hassle. If you get springs all around then you should get about 2.5 inches. At first it might be higher, but the springs usually settle. If you get an add a leaf then the rear WILL sag. Trust me, I know from experience. Stay away from blocks if you can.
    I have a 2.5" lift, and now I am having to get creative to get my truck higher. 33's will fit fine, and thats all I thought I wanted, but after wheelin with guys with 35's it is the only way to go. So now I have a 1" zero rate from ORD in the rear for about 3" of lift and extended HD front shackles from ORD for about 2.75" of lift. To make room for 35's I will add a soft top which will lift it a little and put a zero rate in the front of my truck to get to 3.5-4" of total lift. Its alot of hassle when I could have just gotten a 4" in the first place.
    My Chevy isn't broken, its just out of gas.
  5. Panther
    Panther 1/2 ton status
    Aug 31, 2000
    845
    South Jersey
    If you get all new springs, you might notice more than 2.5" in the back because you will get the new 2.5" plus recover any height you lost from the factory springs sagging.
    <font color=blue>Brilliance is like 4wd, it allows you to get stuck in a more remote location [​IMG]</font color=blue>
  6. UseYourBlinker
    UseYourBlinker 1 ton status
    Jun 7, 2000
    11,117
    I have Procomp 2.5 inch springs on the front of my K5,and I would say they are about 3 inches. There only 3 years old,so I guess with time there gonna sag.
    Eric
    from Freekmont,CA.
    <a target="_blank" href=http://www.community.webshots.com/user/vwryda>The darker side of nonsense...</a>
  7. DuneRunner
    DuneRunner 1/2 ton status
    Aug 1, 2001
    1,252
    Fremont CA
    I too have 2.5 and at first they sat 4 inches. Like everyone said it does sag... I to have ORD front shackels.(sp) I'm going to use 3" springs in the rear and get rid of the blocks. I have yet to have a problem with the blocks. (knock on wood) I like the fact that its not to high. and I'm going to step up to 35's later on. Currently 31's in a few weeks 33's![​IMG]
    Ckeck out my pics. The reason that I only went with 2.5 is cuz in four wheel mag. a few years back they did a good set up with only 2.5 and 35's on a K5...Stincky Blazer was the title.
    Have fun.
    Later <font color=green>KEN</font color=green>
    DANGIT it's not a bronco!
    <a target="_blank" href=http://community.webshots.com/user/kensk5>My Picts</a>
