2.5 or 4 inch
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by blazingboy, Jan 10, 2002.
  1. blazingboy
    blazingboy 1/2 ton status
    Dec 2, 2001
    120
    Georgia
    I got my 33 inch ssr's mounted in my eagle 589's the other day now I just need to decide on which brand and what size lift I was thinking of procomp but not sure I want to get away without fender triming.I don't do much flexing mostly just mud and light trail stuff.
  2. muddysub
    Jun 23, 2001
    10,451
    489
    my garage, Henderson, NV
    go with a 4", if you go with a 2.5" first you'll regret it down the road. my friend did.
    if you have 33"s you won't have to cut the fenders, i don't think. if you don't do a lot of flexin, you'll be fine.
    as for brands, the procomp 4" springs are stiff. (i have em) but if flex isn't really important to you, they'll be fine. but they ride stiff. tough country is the softest i've heard. i've also heard good things about sky-jacker soft ride springs (or ez ride, something like that).
    --Scott, 1989 GMC Suburban 2500 4" lift, 36" TSLs
    <a target="_blank" href=http://community.webshots.com/user/muddysub>http://community.webshots.com/user/muddysub</a>
  3. MR.GADGET
    MR.GADGET Registered Member
    Jan 9, 2002
    33
    Raleigh NC
    Depends on what you are going to be doing with it! I run a 2.5 Skyjacker and love the way it rides on the road and off road it has good flex but when I put a winch and brushguard on it I got some tire rub under good flex so I ordered there Fitted add in spring they sell for snow plows and winchs so it should be fine. I have 33x12.5 Goodyear ATS on a AR 15x10 Baja Rims.
    IF IT'S NOT AS BIG AS YOU ARE DRIVE OVER IT!!!!!!!!!!
  4. 73k5blazer
    Dec 28, 2001
    4,987
    38
    The Rustbelt
    My '73 (before I tore it down and put on a Glass body) had the Skyjacker 2.5" and 33's. It would rub barley under full Flex. Not even enough to bend any metal. I would go with as low as possible to fit the tires you want. Just my opnion, but anymore is just raising the Center of gravity uneccesarily.
    For my Glass body I've kept the 2.5" lift, and with the loss of the weight, I expect to run 35"'s without problem.
    BlazerMan
  5. BLUESMAN
    BLUESMAN 1/2 ton status
    Oct 3, 2001
    951
    Phoenix(but it\'s a dry heat...like an oven!)AZ.
    My stock '78 had 33" tires on it with no lift.I debated with getting a 2 1/2" or an 4" lift,but finally decided on a 4" and run 35's.Well t.he K/5 has not left the driveway since I bought it.I was going to run the stock diffs(Dana44&amp;12 bolt),but a deal came by and I'm ready to install 3/4 ton diffs.AND NOW another deal has come around and I'm going to run 38" tires(I still have the 35's unmounted).So I would get the 4" lift and hope you don't run into too many great deals.Well gotta go and cut some more fenders.AND I THOUGHT I HAD IT ALL FIGURED OUT, HOW I WANTED TO RUN THE K/5!!!
  6. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    Go with a 4". I have a 21/2" lift and I have already started to lift it higher then the 2.5 I started with. The front is up to 2.75 in the front, and 3" in the rear. When I go with 33's (32's currently) I will probably lift it some more. Go 4" that way you don't have to try and get creative with the 2.5" like I am.
    My Chevy isn't broken, its just out of gas.
  7. chvyhs
    chvyhs 1/2 ton status
    Feb 12, 2001
    1,469
    Murrieta, California
    Go with the 4". It will give you the option of going to bigger tires later. Don't spend the money twice. I had a 2.5" lift with 35"x14" Gumbo monster mudders and some cutting. In the end I pushed it up to 4".
    <a target="_blank" href=http://community.webshots.com/user/chvyhs>WebShot Pics</a>
  8. 85HeartBurb
    85HeartBurb 1/2 ton status
    Jan 10, 2002
    735
    Temecula, south
    i would go with the 4" if not you will regret it cause you will want to go higher!!!
    NO LOCKER, STOCK GEARS, NO PWR BRAKES, NO POWER STEERING, NO PROBLEM!
    HIT IT FULL CHICKEN!!!!
  9. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    Go 4" My 33's rub with my 3" just going over curbs slowly...
    90K5
  10. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
    i got 33's on my truck atm, no lift, and a little rub turnin in the driveway, im puttin my lift on this weekend (4" BDS) and when my 33's are worn out, im goin to 35's if they rub ill put on a 1 or 2" body. id go w/ a 4" that way theres no possible way 33's can rub.
  11. Panther
    Panther 1/2 ton status
    Aug 31, 2000
    845
    South Jersey
    Keep in mind, if you go with the 4" lift, they'll be more work involved with the brake lines, driveline angle etc. It seems you can put on a 2.5" lift with no other mods.
    <font color=blue>Brilliance is like 4wd, it allows you to get stuck in a more remote location [​IMG]</font color=blue>
  12. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    I have/had a 2.5" lift. The driveline angles are ok. I got a little vib, but not enough to worry about. The brake lines are another story. If you flex your rig with a 2.5 you just asking to rip a brake line. Definitly change your brake lines if you offroad. Your best off going with a 4" and dealing with the other problems the going with a 2.5". Trust me. I know from experience.
